The Basics of Current-Sensing Relays
Understanding AC and DC current relays can help electrical professionals troubleshoot power quality problems more effectively
A range of manufacturing and production processes rely on current-operated relays to provide a continuously adjustable trip-current setting. They are able to protect mechanical apparatus from jam-up or other overloading conditions that result in measurable increases in motor current. Functionally, they sense current levels and provide an output signal when a specified current level is reached. Current-sensing relays are used to:
  • Signal high-current conditions, such as a clogged grinder.
  • Identify low-current conditions, such as a pump that has encountered a low-water condition. Sense the current a motor is drawing to feed the current to a programmable logic controller (PLC).
To meet the unique requirements of a diverse set of applications, a wide range of devices and options is currently available to designers, installers, and maintenance professionals, including plug-in style, base-mounted, DIN-rail mount, and donut-style. These types of devices offer the following capabilities:
  • Sensing both AC and DC current — from milliamperes to several amperes.
  • Sensing thousands of AC amperes with a current transformer (CT).
  • Current setpoints can be fixed or adjustable.
  • Input AC or DC.
  • Analog output — voltage or current — or contact closure.
  • Self- or looped-power units.
  • Fixed or adjustable internal time delays.
Discuss this Article 0
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Apr. 15, 2013
video
Newsletter Signup
Connect With Us
