Harger Lightning & Grounding Introduces New Ground Rod Driver
Harger Lightning & Grounding proudly introduces its new Ground Rod Driver. The Ground Rod Driver provides a safe, simple, effective and affordable way to install ground rods.
Harger Lightning & Grounding proudly introduces its new Ground Rod Driver. The Ground Rod Driver provides a safe, simple, effective and affordable way to install ground rods. The Ground Rod Driver drives a ground rod to ground level without the need of a stepladder or the use of a heavy sledgehammer. It also drives the rod without deforming the end of the rod.
The Ground Rod Driver includes the driver body with soft, rubber grips, an insert for driving rods to ground level and a retaining strap to hold the insert in place during storage. Heavy-duty steel construction provides maximum driving forces, while the soft rubber ergonomic grip provides user comfort. The 5/8” and 3/4” inserts are interchangeable with the standard driver body and prevent the Ground Rod Driver from slipping off the rod near ground level. The tool is completely self-contained and easy to store.
The Ground Rod Driver can be used on all types of ground rods, including copper-clad steel, galvanized and stainless steel. For more information on the Ground Rod Driver, contact Harger’s Sales Department.
Harger Lightning & Grounding is a leading manufacturer of lightning protection and grounding equipment, as well as exothermic welding materials for the communications and electrical industries. Harger also provides design and engineering services and specializes in offering total systems solutions for their customers.
Discuss this Article 0
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Apr. 15, 2013
video
The Westex Difference
Newsletter Signup
Connect With Us
