• Manufacturer’s Specs Aren’t Always Right
    Sometimes the manufacturer’s specifications don’t fit the application
    Sept. 13, 2016
    STILLFX/iStock/Thinkstock
    Typically when we repair something, we return it to the manufacturer’s specifications. But if the equipment failed, perhaps the manufacturer’s specifications don’t fit the application. When making repairs, do you even ask this question?
    Consider a 30 hp motor that drives a production machine and must be replaced every nine to twelve months. It always gets an exact replacement. What is the typical mode of failure? If heat-related, perhaps a motor with a higher heat rating will last for decades in that same application.
    Perhaps the motor is not quite “torquey” enough. A simple gearbox replacement can solve that problem.
    What if the motor starts across-the-line? If that’s the case, probably a couple of things are going on. First, that kind of start is much harsher on motors than the soft start made possible with a variable frequency drive (VFD). And if that VFD is power factor corrected, it will solve a second problem that’s common with motors.
    Some issues, like the aforementioned, are well within maintenance capability to correct. Other issues require a conversation with the manufacturer.
    Latest from Maintenance, Repair & Operations
    ID 131895857 © Vichaya Kiatyingangsulee | Dreamstime.com
    dreamstime_xxl_131895857
    Strategic acquisition enhances Shermco’s Southeastern footprint with expanded operations near Birmingham
    ID 2280751 © Andreasg | Dreamstime.com
    dreamstime_xxl_2280751
    As the demand for smart, energy-efficient buildings grows, so does the need for adaptable lighting control solutions that blend wired and wireless technologies.
    Courtesy of Pioneer Power Group
    Arc Flash Explosion
    The first update in almost 20 years, OSHA’s latest arc flash guidance is poised to make a lasting impact on safety in the electrical industry.
