• Subscribe
  • About Us
  • Magazine Issues
  • Newsletters
  • Advertise
  • Shop
Skip to Navigation Skip to Content
Electrical Construction & Maintenance (EC&M) Magazine
Register Log In
  • Forgot Your Password?
close
  • NEC
    • Code Basics
    • Q&A
    • Quizzes
    • Violations
    • What's Wrong Here?
  • Design
    • Computers & Software
    • Green Building
    • Lighting & Control
  • Ops & Maintenance
    • Energy Efficiency
    • Metering & Monitoring
    • Motors
    • Test & Measurement
  • Contractor
    • Business Management
    • Estimating
    • Low Voltage & Communications
    • Project Spotlight
  • Safety
    • Arc Flash
    • Fire & Security
    • Shock & Electrocution
  • Power Quality
    • Monitoring & Measurement
    • Sags & Swells & Interruptions
  • Training
    • Workplace Learning Center
    • Events
    • Webcasts
  • Basics
    • Bonding & Grounding
  • Products
    • Product of the Day
    • Product of the Year
Advertisement
Home > Ops & Maintenance > Electrical Troubleshooting Quiz
Feb. 25, 2013
    • EMAIL
  • Tweet
Comments 10
Advertisement
  • Print
  • reprints
  • Favorite
    • EMAIL
  • Tweet
Discuss this Article 10
Anonymous (not verified)
on Feb 26, 2013
If a standard motor starter is utilized for the motor control, vs. a VFD, consider checking for proper coil voltage and proper contactor engagemnet strength. If correct, be sure to check for wear and burning on the contacts themselves. Do to normal arcing and wear contacts may become carboned and will limit proper voltage through the contact creating increased amperage.
  • reply
on Feb 26, 2013
Voltage drop may be an issue. The load, cable size and the distance should be confirmed to calculate the voltage drop.The voltage drop may not be the root cause but can be a contributing cause.
  • reply
on Feb 26, 2013
If you have access to a good thermal imager usit it to scan the electrical connections. We had a situation where we were blowing the fuses in the MCC for a motor but not blowing the smaller fuses in the local disconnect. We found that a loose connection in the MCC was causing the problem. Unce the connection was cleanes and tightened the problem went away.
  • reply
on Feb 26, 2013
Verify the pressure is acurate you could be starting against a higher pressure in the recieving tank which could intermittently cause the fuses to blow. The pressure switch could be bad or out of calibration.
  • reply
Tim (not verified)
on Feb 26, 2013
I'd check the following:
1 contactor(s), both if lead/lag used
2 compressor motor bearings
3 reservior tank backcheck valves (400 psi is hell of a head!)
  • reply
Louconstant1 (not verified)
on Feb 26, 2013
You stated that you have 200hp motor, need more info, name plate,voltage, amps, hp, three phase? Letter? Etc. motor type, wire size? Then we can determine and come up with a solution. Using 2011 NEC -NFPA
Thanks louconstant
  • reply
on Feb 26, 2013
call an electrician, lolzzz
  • reply
on Feb 27, 2013
Based on the information already submitted I would also check the power factor and see if power factor correction is faulty or necessary. A 200HP motor is a large load to be starting across the line. I definitely would use a VFD or soft-start device for that large of motor regardless. If you have test equipment a power quality analyzer measuring the start up wave-shapes would provide valuable information as to the problem by indicating uniformity, voltage and current magnitude, angle, etc.
  • reply
sparky Jr. (not verified)
on Feb 27, 2013
Allways increase the wire size For 200 H.P You should
go up to the next size that will solve your problem remember I squared X ressistence= less Heat!
  • reply
on Mar 11, 2013
A lot of great suggestions. Sounds like possible Harmonic Currents. Testing with a True RMS Volt meter and Amp meter will tell the difference.
  • reply
Post new comment
(optional)
Sponsored Links
Related Articles
  • Electrical Troubleshooting Quiz 5
  • Electrical Troubleshooting Quiz 1
  • Electrical Troubleshooting Quiz 4
Sponsored by
EC&M Learning Center
2011 Electrician Exam Preparation Book & Journeyman Simulated Exam
Printed in full color, the 2011Exam Prep book covers Theory, Code, and Calculations in great detail. Clear colorful graphics...
2011 Understanding NEC Requirement for Solar Photovoltaic Systems
Solar power is new to most in the electrical industry and this expanding and exciting industry has created many NEC...
Photovoltaics for Commerical and Utilities Power Generation
This book provides an in-depth review of the solar industry development, and present-day state of the art, emphasizing...
BROWSE ALL TITLES
Advertisement
Webinars
ON DEMAND: All You Ever Wanted to Know About GFCIs & AFCIs
Abstract:  In this webinar, Mike will not only explain the current NEC requirements for GFCIs and AFCIs, but he'll explain how they operate, what causes their premature failure, and when they won't provide the safety protection you might have thought they would.
Sponsored by:
ON DEMAND: Workplace Electrical Safety: Prevention before Protection
Abstract: This webinar will teach attendees the difference between risk and hazard, and how the choice of system grounding has a direct impact on reliability and safety.
Sponsored by:
MORE WEBINARS
Advertisement
Adjustable Depth Mounting Brackets | Arlington Products
Jun. 17, 2013
Video
Electrical Construction and Maintenance
Arlington: Adjustable Depth Mounting Brackets
Arlington’s new non-metallic adjustable mounting brackets are perfect for low voltage installations when the final wall thickness is unknown. Set for a 1/2" thick wall finish, they adjust to accommodate a finished wall up to 1-1/2" thick. Support tabs deliver extra-secure mounting of bracket to wood or steel studs in new constructions....More
Showing 3-3 of 21 items
  • prev
  • 1
  • 2
  • 3
  • 4
  • 21
  • next
BROWSE ALL VIDEOS
equipmentone.com
Search 2.5+ million listings
prev next
Newsletter Signup
Sign-up to receive our free newsletters
Subscribe
Connect With Us
  • Twitter
  • Facebook
  • Linked In
  • RSS
Advertisement
Ecmweb.com
  • NEC
  • Design
  • Ops & Maintenance
  • Contractor
  • Safety
  • Power Quality
  • Training
  • Basics
  • Products
Site Features
  • Author Guidelines
  • RSS
  • Sitemap
  • Site Archive
  • Subscribe
  • View Mobile Site
EC&M Corporate
  • Privacy Statement
  • Terms of Use
  • About Us
  • Advertise
  • Contact Us
Follow Us
  • Twitter
  • Facebook
  • Linked In
  • RSS
Search ecmweb.com
Subscribe to the print magazine
PISCES
Related EC&M Sites
  • Electrical Wholesaling
  • Electrical Marketing
  • Transmission & Distribution World
Copyright © 2013 Penton
Sponsored Introduction Continue on to (or wait seconds) ×
