ECM Buyers' Guide
What's Wrong Here
Jul 8, 2004 1:22 PM, By Joe Tedesco
If you look closely, you can see an electrical panel hiding behind the copper piping system. The panel is now inaccessible. It’s hard to believe that the heat and plumbing system passed inspection – or did it?
This installation violates working space rules as noted in 110.26 (Spaces About Electrical Equipment) of the 2002 NEC, which states “Sufficient access and working space shall be provided and maintained about all electric equipment to permit ready and safe operation and maintenance of such equipment.”
Sec. 110.26(A) (Working Space) goes on to state, “Working space for equipment operating at 600V, nominal, or less to ground and likely to require examination, adjustment, servicing, or maintenance while energized shall comply with the dimensions of 110.26(A)(1), (2), and (3) or as required or permitted elsewhere in this Code.”
Acceptable Use Policy
what's wrong here?
Jul 2, 2009 6:51 PM
Jun 18, 2009 4:01 PM
Jun 4, 2009 1:26 PM
View all What's Wrong Here?
Recent Comments
Follow comments on ecmweb.com
i-Gard contest
Here’s your chance to win $5000! All you have to do is submit a case history based on your or your client’s experience (positive or negative) in applying HRG technology to an existing or new power distribution system.
EC&M White Papers
Protecting Generators through Hybrid Grounding
The industry has recently become aware of the problem of severe generator damage due to stator ground faults. Two factors have been identified as contributors to this growing problem
Retrofit 2-Gang TV Box(TM)
Arlington’s recessed two-gang TV BOX™ for old work allows you to mount LCD and plasma TVs, and other system components flush against the wall...
Hybrid Grounding - The industry has recently become aware of the problem of severe generator damage due to stator ground faults. Join us for this live webinar!
Arc Flash HazardThe 3 As of Arc Flash - Awareness, Analysis, Action
resources
product info icon
product info
tradeshow icon
tradeshow
research icon
research
rss icon
rss
Browse Back Issues
Browse Back Issues
