ECM Buyers' Guide
Illustrated Catastrophes
Jun 1, 2006 12:00 PM, By Joe Tedesco, NEC Columnist
All references are based on the 2005 NEC.
Taking Perfect Aim. Karl Darby, owner, Darby Electrical, Stockton, N.J., found this installation at his new next door neighbor's house. “Once the house was finished, and we headed over to meet the new neighbors, I spotted the electric service. As you can see, it appears the cable TV installer drilled a hole from the cellar, out through the siding, and right through the service lateral conduit, apparently without hitting an energized conductor. Amazing! The best part is they neatly caulked the penetration after installing their coax. Also note the grounding wire is disconnected.”This work shows a clear lack of proper training, which could have easily resulted in a fatality. This installer was most likely unaware of what could have happened to him if the drill penetrated the energized conductor. Lucky for him, it probably penetrated the grounded (neutral) conductor. The NEC doesn't list a specific rule for disconnecting the lateral with service entrance conductors in it.
Burning Down the House. David J. Delany, P.E., senior electrical engineer, FreemanWhite, Inc., Raleigh, N.C., ran across this arrangement in a friend's 20-year-old house. “I found it like this when I removed the panel cover to install a new breaker for him. I don't have a picture of the meter socket, but it was just as burnt up. It looks like a few things caused this problem. The panel is located in a utility room attached to the house. The room is accessed via an outside door, which is left open at times, allowing damp conditions at the panel. Combine this with aluminum conductors and loose connections and the result is overheated conductors. Luckily, the house didn't burn down before the equipment was replaced.”
Remember to torque those connections as required by the instructions on the panel, and watch out for those long trim screws. The screw on the right top originally penetrated the hot phase conductor and helped cause this damage because of the missing main bonding jumper.
Found a Code Violation? E-mail your photos to Joe Tedesco at joseph.tedesco@yahoo.com.
Acceptable Use Policy
what's wrong here?
Whats Wrong Here?
Mar 11, 2010 12:54 PM
Feb 18, 2010 5:04 PM
Feb 4, 2010 5:06 PM
View all What's Wrong Here?
product of the week
CAD Software
March 15, 2010
CAD Software
View all 2010 Products of the Week
Shocking Stats
54
More Industry Statistics
Recent Comments
More...
Professionals provide answers to your questions. Become an expert!
Arlington CED1 Entrance Hoods
The Scoop Series CED Entrance Plates and Hoods are reversible, non-metallic, single and two-gang versions...
Gain years worth of insight with Southwire’s 2009 Cable Innovation Road Show with Grounding Seminar!
George Brown College
Online Tech Training – Electronics, PLC, and Robotics programs at George Brown College.
Listen
Listen
resources
product info icon
product info
tradeshow icon
tradeshow
research icon
research
rss icon
rss
Browse Back Issues
Browse Back Issues
