Question: Is type NM cable permitted to be laid across the top of trusses in an attic without being stapled?
See answer below.
Answer: No.
Explanation: Section 334.30 requires NM cable to be supported AND secured at intervals not exceeding 4-1/2 ft. The trusses would provide support but not the required securing thus staples would be needed.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected]
John Lupacchino
Senior Design Engineer
