Based on the 2023 NEC.
Question: What is the minimum size conductor that may be run in parallel?
See answer below.
Answer: 1/0
Explanation: Article 310.10 (G) (1) permits paralleling of 1/0 and larger.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected]
