ID 177037660 © Zvonkov Eugene | Dreamstime.com
Dreamstime M 177037660
Code Quiz: Motor Conductor Calculations
Aug. 5, 2021
Test your Code knowledge.
Based on the 2020 NEC.
Question: What is the minimum ampacity for a conductor supplying a 480V 10 HP motor with a nameplate current of 13A?
 See answer below.
Answer: 17.5A
Explanation: Section 430.6(A)(1) requires the current value for sizing conductors to be based on Table 430.250. For the motor listed above, the value would be 14A. Section 430.22 requires this value to be multiplied by 125%.
14A x 125% = 17.5A
John Lupacchino | Senior Design Engineer
