A rash of motor failures has afflicted your plant. Your plant engineer read some application notes from the Web site of a test instrument manufacturer and subsequently used a power analyzer on the feeders of these motors. There were some anomalies, but nothing that explains these failures.
These failures are occurring in a few unrelated systems: the plant HVAC, a process exhaust hood, a scrap grinder, a conveyor system, and a wash tank. These same systems keep having motor failures. What should you look at to get to the bottom of this problem?
Your biggest clue here is the localized failures, which tell you it's not a systemic issue such as voltage distortion. Your second biggest clue is that they are repeating. When you combine the two clues, you can conclude that something is happening in these specific systems.
If you understand that improper repairs lead to repeated failures, then you understand that the most likely cause of this rash of motor failures is improper repair. If it was a motor maintenance issue, then it would be affecting other equipment as well. However, the problem is limited to equipment that has undergone repair.
To solve this issue, look for errors in the repair process. One thing you can do is to see if the repair procedure provides (or refers to) the torque spec for the mounting of each motor. If this information isn't readily available, then you have identified one likely cause.
To identify other potential causes, walk down each step from replacement motor specification to startup of that motor. Any step along the way could be responsible for premature failure of replacement motors.
Acceptable Use Policy
what's wrong here?
May 10, 2012 12:44 PM
Apr 19, 2012 10:09 AM
Apr 5, 2012 2:27 PM
View all What's Wrong Here?
product spotlight
EV charger tester
May 25, 2012 8:26 AM
EV charger tester
Free Product Info
Recent Comments
More...
Social Media
More ways to stay informed...
follow us on twitter
Find us on Facebook
EC&M Whitepaper
Date: Wednesday, May 30, 2012
Time: 2:00pm ET
Grounding Versus Bonding
Now Available On-Demand
resources
product info icon
product info
tradeshow icon
tradeshow
research icon
research
industry links
industry links
rss icon
rss
Browse Back Issues
Browse Back Issues
