Following the old adage “use the right tool for the job” can dramatically improve repair turnaround. Here’s one common example. Everyone’s familiar with the adjustable wrench. The advantage of it is you can adjust the jaw distance to fit a range of fasteners. But this tool has its disadvantages too.
The disadvantage is that adjustment involves a series of steps to get a minimum-slip fit:
- Put the wrench on the fastener, tighten down.
- Pull the wrench off, tighten slightly.
- Push the wrench onto the fastener.
- Repeat several times while using.
Plus, the jaws are directional. To save time, obtain the specific wrenches for the fasteners in your equipment.
Special dies are another example. The big problem with these is they tend to get used well past the point at which they are worn out. Inspect and replace dies regularly, before they are needed to repair critical equipment.
A dying power tool doesn’t make for a quick repair, either. Keep spare batteries and chargers available. Implement a power tool battery maintenance program.
