ECM Buyers' Guide
Failure Mode Analysis
Jul 7, 2009 3:28 PM
Simple failure-mode analysis consists of looking up the description of a failure (that's the "mode" we're talking about) in a chart and seeing the corresponding cause. For example, the chart might show "burnt winding" and list "overheating" as one of the possible causes.
However, this approach is often too simplistic. What caused the overheating? Did unbalanced voltage do the deed? Perhaps misalignment and vibration were the villains — the motor is drawing more current to do the same amount of useful work.
A complete failure-mode analysis requires going all the way back to the root cause of the condition. Solve that cause, and the entire chain of causes for that mode disappears. Use a multi-layered approach to failure-mode analysis to get at the source issue.
MRO Insider
NEC in the Facility
Jan 15, 2010 3:14 PM
Does your facility have any areas used for spraying, dipping, or coating processes? If these operations run regularly, you must apply Art. 516 [516.1]....
Make Procedures Helpful, Part 3
Jan 15, 2010 3:12 PM
A common problem with repair procedures for complex equipment is that the sheer amount of text they include makes them unwieldy and, often, overwhelming...
Jan 15, 2010 3:10 PM
The plant air system has shut down in the middle of a critical production run three times in the past month. Each time, a blown fuse had to be replaced...
NEC in the Facility
Jan 4, 2010 4:36 PM
Retrofits, upgrades, and additions can result in a change to the "total load" used for sizing service conductors....
Acceptable Use Policy
what's wrong here?
Feb 4, 2010 5:06 PM
Whats Wrong Here?
Jan 21, 2010 4:40 PM
Jan 7, 2010 12:47 PM
View all What's Wrong Here?
product of the week
Enclosures
February 8, 2010
Enclosures
View all 2010 Products of the Week
Shocking Stats
54
More Industry Statistics
Recent Comments
More...
Professionals provide answers to your questions. Become an expert!
Arlington CED1 Entrance Hoods
The Scoop Series CED Entrance Plates and Hoods are reversible, non-metallic, single and two-gang versions...
Gain years worth of insight with Southwire’s 2009 Cable Innovation Road Show with Grounding Seminar!
Listen
Listen
resources
product info icon
product info
tradeshow icon
tradeshow
research icon
research
rss icon
rss
Browse Back Issues
Browse Back Issues
