Electrical Troubleshooting Quiz, Oct. 9, 2012
Ever since a recipe change on some large mixing tanks, the drive shaft between the motor and its gearbox has been shearing
Ever since a recipe change on some large mixing tanks, the drive shaft between the motor and its gearbox has been shearing. So have some of the shafts between the gearbox and the impeller. The recipe change calls for a longer time for the solution to sit and react before being mixed, resulting in a much more viscous fluid.
The system engineer has tried hardened shafts, but an old-timer says that will never work. He looked at the end of a broken shaft, said the break was torsional, and declared this an electrical problem. What if the old-timer's right?
If the old-timer correctly read the shear pattern, his conclusion is probably correct. Hardening a shaft makes it more scratch-resistant; the issue here is torsional strength.
Someone needs to evaluate the shaft diameter against the elasticity modulus of the steel. While most electrical engineers can vaguely recall this from Physics 101, a toolmaker or mechanical engineer is probably the best person to determine if the shaft is the wrong size or material for the rotational strength needed to handle torque required to move an impeller through that fluid.
But the twist here, so to speak, is the motor must start under load. The initial starting torque is greater than the running torque. That would make this an electrical problem, because the fix will be in the controls.
Install and adjust any these three devices, to eliminate that high starting torque:
1.    VFD (input).
2.    Soft-start (input).
3.    Magnetic drive (output).
Discuss this Article 1
Drewman (not verified)
on Oct 10, 2012
Had a similiar situation when I designed/fabricated a mixer for our company's 3000gal.holding tank. Essentially I had a 12"dia propeller on a 6' x 1" s/s shaft w/pillow block bearings driven by 3ph.gearmotor.Although the shaft withheld the torque,the geardrive unfortunately did not.I'm in agreement with the forementioned you listed.I wound up replacing the geardrive with a lowered rpm unit,wireing an interval TD relay, reversing the phasing,optimizing push/pull thrust action.Total cost to build was $1500 vs Mfg.unit for $5000. Company cost $avings and American Know how.
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Apr. 15, 2013
video
The Westex Difference
Newsletter Signup
Connect With Us
