The industrial engineer at your plant bought a light meter a few years ago. Whenever a line is redesigned or a layout changed, he wants the lights moved a bit to get the desired light readings. Now he’s presented you with a problem. He says the lighting has been deteriorating. “I get fewer lumens every time. Instead of moving a given fixture a little bit, we now have to position it exactly. And we’re adding task lighting.” On his workstation, he shows you a trending ...
Website Registration Required to Access this Content
Only registered users have access to Silver content.
Registration on EC&M allows you exclusive access to high value content centered around proprietary research, expert NEC analysis and in-depth technical procedures.
Already registered? here.
