Safety
Here are some rules about chemical containers you should be aware of and follow:
- Don't write on container labels, and don't remove them.
- Label any container you use before pouring the chemical in it.
- You can use a smaller "work container" rather than the big can of solvent or whatever it is you’re using. However, use a proper container, not a cut-off soda or coffee can.
- If something's in an unmarked container, don't use it. If the label isn't clear, treat the container as unmarked. Report such containers to your supervisor.
- For some substances, you can return the unused material to the original container. For other substances, you can’t. Know the answer to the return/dispose question for every material you're using.
- Properly stow (dispose of or return) materials when you no longer need them for the day (end of shift or end of task, whichever is first).
- Don't mix substances or chemicals, unless your work procedure calls for it. Mixing the wrong chemicals can prove fatal.
Latest Articles
EV charger tester
May 25, 2012 8:26 AM
CFL/LED dimmer
May 24, 2012 8:48 AM
Load bank
May 23, 2012 9:33 AM
Trending Articles
advertisement
what's wrong here?
May 10, 2012 12:44 PM
View all What's Wrong Here?
What's Wrong Here
Sponsored By:
product spotlight
EV charger tester
Free Product Info
