Bad maintenance practices tend to sneak into the way things get done. Here are three more related to “test equipment that you should guard against:
Bad Practice #56 — Thinking That “DMM” and “Test Equipment” Mean the Same Thing.
While the DMM can do many things, it’s one part of a larger test equipment strategy. The DMM can’t tell you anything about insulation integrity, motor vibration, or a host of other important metrics. Use the right tool for the job.
Bad Practice #57 — Foregoing Recommended Maintenance Tests Because You Can’t Budget for the Test Equipment and Training to Perform Them.
At some point, these expenses become the “necessary cost of doing business.” A leasing plan can reduce equipment purchase budget pressure. If training costs are prohibitive, hire an electrical testing firm. However, make sure and look for industry certifications when doing so.
Bad Practice #58 — Following a “Check Off the Box” Approach to Test Equipment Purchases.
Getting the economy model of insulation resistance tester or power analyzer does allow you to say you’ve got that type of equipment. But do you have the right solution for your particular needs?
