Moving Violations Video No. 120: Illegal Touching of Cables
Discuss this Video 5
on Jun 2, 2016
Come on now, this was pure clickbait. Headline on Codewatch email was "What Happens when cables are illegally touching." One would expect something exciting to occur.
I hope this is not going to become a common technique for page views.
on Jun 2, 2016
Sounded perverted, I had to look!
on Jun 2, 2016
What if you use Article 336 with Type TC UL 1277 600V Ethernet cable? Or refer to NFPA 79? Article 800 is for premises.
on Jun 2, 2016
The real violation is in the engineering. This looks like a box that might have come from a manufacturer this way. Notice the 120V (assumed voltage) block at the lower right? And why is there a splice in this box?
I see more than just a wiring violation. This appears to go back on the manufacturer. Just how many products are out there like this where no one at the manufacturing end actually looked at this?
on Sep 3, 2016
Russ, what is the insulation resistance value of the low voltage wiring in this video? Suppose the insulation value was the same or higher than the other wires shown in your video. What would be the violation other than poor workmanship? Again, thanks for airing this video.
Please or Register to post comments.
Electrical Testing Feed
Join the Discussion on EC&M Talk
EC&M Webinars
Nov 9, 2016
Webinar
Technology Enabled Data Center Life Cycle Services
This webinar will discuss the benefits of cloud connected data center monitoring, different levels of monitoring and the potential effects on availability and efficiency....More
Nov 2, 2016
Webinar
There is More to a Data Center than White Space; A Holistic Approach to Facility Monitoring and Control
EC&M Learning Center
Connect With Us
Sponsored Introduction Continue on to (or wait seconds) ×
