Security Risks
How secure are industrial control systems within today's facilities from cyber threats
Until a few years ago, breaches in cybersecurity, largely consisting of data theft and invasions of privacy for financial gain, were strictly the domain of information technology (IT). However, in March 2007, researchers at the Idaho National Laboratory, Idaho Falls, Idaho, at the behest of the U.S. Department of Homeland Security (DHS), demonstrated the vulnerability of a diesel generator by hacking in from a remote access point and causing it to self-destruct. Although the official report on the experiment, named Project Aurora, is classified, a video showing the generator malfunctioning with thick smoke coming out of it captivated viewers on the Internet. Project Aurora demonstrated the potential of malicious cyber attacks to compromise critical infrastructure through manipulation of industrial control systems (ICSs). However, at the time, this type of attack seemed only a remote possibility.
The Stuxnet virus brought awareness to security issues surrounding control systems at facilities such as power plants like this nuclear plant.
Then, in July 2010, it was revealed that a virus had targeted the programmable logic controllers (PLCs) controlling the centrifuges of an Iranian nuclear facility in Natanz located in central Iran. After inspectors with the International Atomic Energy Agency noticed an unusual number of decommissioned damaged centrifuges at the plant, it was eventually discovered that in June 2009, the malicious software, or malware, had made its way — most likely through infected USB flash drives — into computers in the plant.
The virus, named Stuxnet, used a number of  “zero-day exploits,” which means the worm was created to exploit vulnerabilities in software that had no known patches. Although the malware first exploited the LNK file of Windows Explorer to covertly place an encrypted file from the USB stick onto computers, German ICS security expert Ralph Langner eventually figured out that its true aim was Simatic WinCC Step7 software, an ICS manufactured by German electronics and electrical engineering manufacturer Siemens, which has been installed to run the PLCs that control motors, valves, and switches in industries worldwide.
Langner’s conclusion was a surprising revelation. Previously, ICS and automation equipment were proprietary and ran on isolated, stand-alone networks. Because of this, they were believed to be off the radar regarding cyber attacks or not profitable to hackers who were mostly seeking financial gain. Therefore, an alarming lesson learned from Stuxnet was its ability to infect machines that weren’t connected to a computer network or the Internet. Furthermore, in recent years, ICSs have increased their interoperability and are more often connected to the Internet. Creating more reliable and usable systems through automation and remote access can actually make them more vulnerable.
“Arguably, Stuxnet was the first case of a sophisticated attack that was meant to damage equipment,” says Joe Weiss, managing partner of the San Francisco Bay Area-based Applied Control Solutions, which provides consulting services relating to the optimization and security of ICSs. Weiss, in addition to Langner, is recognized as one of the few experts in ICS security. A 35-year veteran in the field of industrial instrumentation controls and automation, with more than 10 years in ICS cybersecurity, he serves on  numerous ICS security standards organizations and is author of the book Protecting Industrial Control Systems from Electronic Threats.
“Before, this was pretty simple,” Weiss continues. “If you had a problem, it was because a valve had a bad design, and that was easy enough to fix. Or you had a problem with boiler control software. When you fixed the boiler control software, it was done. Now this is ongoing. Every time you make a change, the question is: Have you done something to create a cyber vulnerability that wasn’t there before?”
Law of Opposite
Unlike Stuxnet, not all cyber incidents involving control systems are intentional. For example, the natural gas pipeline failure in San Bruno, Calif., which killed eight people in September 2010, was most likely caused by work being done on an uninterruptible power supply (UPS) system located about 39.33 miles southeast of the accident site, according to the National Transportation Safety Board’s report. During the course of this work, the power supply from the UPS system to the supervisory control and data acquisition (SCADA) system malfunctioned so that instead of supplying a predetermined output of 24V of direct current (DC), the UPS system supplied approximately 7VDC or less to the SCADA system. Because of this anomaly, the electronic signal to the regulating valve for Line 132 was lost — the loss of the electrical signal resulted in the regulating valve moving from partially open to the full open position, as designed.
In 2007, a DHS demo showed that emergency generators can be vulnerable to cyber attacks.
Whether intentional or malicious, Weiss uses the NIST definition of a cyber incident, which is electronic communication between systems that affects confidentiality, integrity, and/or availability — the CIA triad. For control systems, availability has the biggest impact. “We’re talking about the availability of a system or a process,” says Weiss. “That’s where this gets to be very different from IT, which is about the loss of communications to an IT computer.”
As an example of loss of communication in control systems, Weiss uses a broadcast storm (too much data on the network) at the Browns Ferry Nuclear Plant, which resulted in the loss of two 10,000-horsepower main coolant pumps.
Until recently, the priorities for design requirements for control systems consisted of performance, reliability, and safety — not security. “Security is not only a new constraint, but also often goes in the opposite direction of reliability and safety,” says Weiss, who explains that securing a system requires retrofitting new security requirements where none previously existed. “You’re not building a new system from scratch. You’re putting requirements into a system that go exactly the opposite of why the system works in the first place. You’re making it more complicated.”
According to Weiss, Stuxnet is a great example of the differences between security for control systems and IT. “Many people focused on the Windows zero-days, but they were simply a delivery vehicle,” Weiss explains. “The warhead affected the controller by changing the controller logic. This was an unexpected ICS attack for which no IT security solution applied then or applies now.”
Therefore, security for control systems should not be approached in the context of IT. Consequently, says Weiss, the security requirements are not based on what it takes to secure a control system against control system threats, but for IT systems (Windows servers and PCs) used in control system applications against IT threats.
Unfairly then, ICS devices, which have proven safe and reliable for years, have been accused of failures in security. “The devices are really good, well-designed, reliable, and safe systems,” says Weiss. “They were never meant to be security systems, but now they’re being accused of not doing what they were not designed to do. How’s that for a double negative?”
100 Days
Because of its stealthy nature, the Stuxnet worm was not discovered for more than a year as it did not directly affect the performance and safety of its targeted nuclear plant. Moreover, because the vulnerability it exploited was a design flaw and not patchable, DHS didn’t even call it a vulnerability, says Weiss. “It wasn’t a design deficiency for reliability or safety; only for security,” he says.
However, since the discovery of Stuxnet and the vulnerabilities it exploited in the Siemens controllers, there’s been a move toward finding similar vulnerabilities in other controllers, particularly with the hard-coded default passwords. “That’s common in controllers from many of our vendors,” says Weiss. “They’ve always been there, but now people are starting to find them.”
In the past, availability has trumped security for facilities such as water treatment plants.
For instance, for the last six months, Billy (BK) Rios, security expert at Google and former security engineer for Microsoft, and Terry McCorkle, an information security red team member for Boeing, have undertaken an independent ICS security project. The two set out to find 100 security flaws in 100 days so that they could then present their findings at a conference. “We wanted to take a look at the state of security for other control systems in general,” says Rios. “We wanted to approach it from the perspective of what can two regular guys do without a charter and without a lot of money when it comes to control systems and their security.”
The pair began requesting free trial software and auditing it in their spare time on nights and weekends. Instead of the 100 bugs in 100 days, they ended up finding more than 600 in 100 days. “When I look at what a modern, secure machine and robust software look like, control systems software does not fall into that category,” says Rios. “The software robustness and security of Apple’s iTunes is probably better than 99% of the control systems I’ve seen out there, both at the hardware and the software level —that’s pretty sad.”
Rios and McCorkle reported their findings to the Industrial Control Systems Cyber Emergency Response Team (ICS-CERT), overseen by DHS, which has since issued some public advisories based on their research. Recently, ICS-CERT published an alert regarding Internet-facing control systems. The ICS-CERT warning lists five reports so far in 2011 of SCADA and ICS systems exposed using scanners, and warns asset holders to secure their systems. “The thing we found to be the most disappointing piece is that implementers usually don’t know about this kind of stuff,” says Rios. “They buy the software from whatever vendor, and they implement it into their own environments, on their own networks, and they’re just completely vulnerable to all sorts of crazy stuff.”
In addition, Rios and McCorkle work with ICS-CERT to notify software vendors of their vulnerabilities. “We’ve been working with those guys to basically contact vendors and have them fix their software,” says Rios. “It’s a very sensitive subject. They don’t want to go to their customers and say, ‘Yeah, our software quality from a security standpoint isn’t very good.’ They don’t want to say that to people, for obvious reasons.”
Currently, Rios and McCorkle only share their research with ICS-CERT. However, they have plans to go public with a database of their findings. “At some point, we’re going to make these vulnerabilities public,” says Rios. “That way, people implementing the software will have some idea that they have these exposures, and they can take other mitigating actions to prevent exploitation of these vulnerabilities.”
In the meantime, Rios discusses some of the research on his blog at: http://xs-sniper.com. When the announcement of the final project comes, it will be published there.
Until the vendors take notice, however, both they and the integrators are in a bind, according to Weiss. “The vendors aren’t going to build a new secure system that costs more money if the end-users aren’t willing to pay more money for a secure system,” he says. “And the end-users aren’t going to specify a more secure system that costs more money and may or may not be as reliable as an older one without security if they’re not forced to do so. It’s a catch-22.”
The Official Octopus
Eventually, Langner came to realize that Stuxnet wasn’t just targeting the Siemens controller; its code contained information about the specific technical configuration of the nuclear facility. It was only targeting that particular facility. As such, Stuxnet was not treated as a wide threat to critical infrastructure that relies on automated systems, such as the electrical grid, transit systems, and sewage treatment plants and dams, or even non-critical systems such as automation for manufacturing facilities and electrical and mechanical systems for offices, schools, and hospitals. Also, because the attack slowed down the Iranian nuclear program, it was reported in a positive light. “Because it happened to Iran, and it was done to a centrifuge, people looked at it as a good thing,” says Weiss. “People are going, ‘Well, I don’t have a centrifuge; therefore, it can’t affect me.’ So, unfortunately, the security guys went nuts with it, but most of the operations people basically went, ‘Well, that’s interesting, but it doesn’t affect me.’ It hasn’t had nearly as much of an impact as we thought or we hoped it would in terms of getting people to do the right thing and secure their systems.”
Still, there have been some efforts made to improve ICS security. In the last year, the Obama administration launched a “cyber command” at the U.S. Department of Defense, which has improved coordination between the Pentagon’s efforts and the DHS’ initiative on the civilian response to cyber threats. Yet, although some regulatory agencies have laid out best practices for guarding against exploits, compliance is voluntary, and, according to Weiss, is often missing input from ICS experts. “Arguably, there are only a limited number of people who are actually control system cybersecurity experts,” says Weiss. “However, those people are generally not consulted when the subject of control system security is raised. The Enduring Security Framework (ESF) Operations Group not only has no control system experts, but it also hasn’t even included control system suppliers in the mix.”
Continue to page 2
Acceptable Use Policy
what's wrong here?
May 10, 2012 12:44 PM
Apr 19, 2012 10:09 AM
Apr 5, 2012 2:27 PM
View all What's Wrong Here?
product spotlight
EV charger tester
May 25, 2012 8:26 AM
EV charger tester
Free Product Info
Recent Comments
More...
Social Media
More ways to stay informed...
follow us on twitter
Find us on Facebook
EC&M Whitepaper
Date: Wednesday, May 30, 2012
Time: 2:00pm ET
Grounding Versus Bonding
Now Available On-Demand
resources
product info icon
product info
tradeshow icon
tradeshow
research icon
research
industry links
industry links
rss icon
rss
Browse Back Issues
Browse Back Issues
