Ivary/iStock/Thinkstock
Wrench And Gears Image
Do You Repair or Just Reduce Damage?
Nov. 30, 2020
Questions to ask when a motor fails due to the conditions of use
Most repairs are done in response to an equipment failure. Restoring the equipment to operation as soon as is practical is usually the goal.
Suppose a motor fails due to the conditions of use. These include a high ambient temperature, load shocks, and frequent stopping/starting. Is replacing the motor a repair or just a reduction in damage?
The motor system has other components subjected to the same or similar stresses. Did you perform a PM on the motor starter? If the motor is VFD controlled, did you at least run the system diagnostics? Did you perform a visual and thermographic inspection of electrical connections? Did you calculate voltage imbalance?
Did you inspect the motor base and pedestal for damage such as cracks? Are the bolts in good condition or heavily rusted?
Did you perform a visual and thermographic inspection of all mechanical connections, such as load couplings? If there is a gearbox, did you perform a vibration analysis (to predict bearing failure) and check the lubrication date?
Chapter 9 of the NEC — Part 5
