What is in this article?:
- Lighting Controls for Intelligent Buildings
- SIDEBAR 1: Standards Development
- SIDEBAR 2: Demand Response Control
- Sidebar 3: Electronic Circuitry Adds Efficiency
Why total light management holds the greatest opportunity for energy savings in commercial buildings
An electronic linear fluorescent dimming ballast changes the 60 cycle waveform from the power source into a high frequency AC waveform while also regulating the current flow. Constant current pulse width modulation is used for the dimming function, which is expressed as a factor (percentage) of relative lamp output, or power. The dimming range extends from full output (100%) to the lowest level, typically 1%. Full output, in turn, is based on the ballast factor (e.g. 0.88, 1.00 or 1.18). Generally, the change in light output — either raising or lowering — is not noticeable to the occupants. Interestingly, when fluorescent lamps are dimmed, the human eye may perceive a higher light level than is actually being produced, because of adaptation.
