• Overhead Service Conductors, Part 1
    Know whether the conductors have adequate mechanical strength for the support provided for a given span.
    May 24, 2016
    HildeAnna/iStock/Thinkstock
    Part II of NEC Art. 230 provides the requirements for overhead service conductors. The bulk of Part II is devoted to clearances and supports. Part II starts off by requiring that all overhead service conductors be insulated or covered [230.22]. The next set of requirements is for the size and rating [230.23]. Some minimum sizes are specified, and the conductor ampacity must be sufficient for carrying the load, as calculated per Art. 220.
    What may be puzzling about this set of requirements is the one stating the conductors must be large enough to “have adequate mechanical strength.” Adequate for what? And how do you calculate the strength, using what material data and what equations?
    There’s a reason for this vagueness: the NEC is relying on the installer to exercise engineering/craft judgment. The strength requirement isn’t specified in any detail, but is there as a reminder to add that consideration when performing the design and installation. If you’re qualified to do the work, you’ll know whether the conductors have adequate mechanical strength for the support provided for a given span.
    Latest from Design
    DLFNY
    beacon_awards
    Proceeds fund the Lana Lenar Lighting Empowerment Scholarship
    ID 131895857 © Vichaya Kiatyingangsulee | Dreamstime.com
    dreamstime_xxl_131895857
    Strategic acquisition enhances Shermco’s Southeastern footprint with expanded operations near Birmingham
    ID 2280751 © Andreasg | Dreamstime.com
    dreamstime_xxl_2280751
    As the demand for smart, energy-efficient buildings grows, so does the need for adaptable lighting control solutions that blend wired and wireless technologies.
