Events
RSS
ON DEMAND: Workplace Electrical Safety - Prevention Before Protection 7
Thursday, May 9, 2013
Past Event:
Workplace safety is a "Must Do" for every business and electrical safety is no different, especially given the devastating impact of the arc flash hazard. The webinar will teach attendees the difference between risk and hazard, and how the choice of system grounding has a direct impact on reliability and safety. It will also describe how to use the systemic approach outlined in ANSI Z10 to drive an effective workplace electrical safety program.
The webinar will discuss the application of ANSI Z10 as a framework for Workplace Electrical Safety and the clear and stark difference between prevention and protection and which should be the first choice every time.
Attendees will learn:
  • how to deploy proven and available technology  to eliminate hazards (prevention),
  • how to substitute the hazard for a lower level of hazard (protection)
  • how to use engineering controls (protection) to ensure a safer working environment.
Technologies that will be discussed in the presentation will  include High Resistance Grounding and its benefits with respect to electrical reliability and safety and the easy steps that can be taken to convert ungrounded systems  to the safer HRG system; a system that reduces the arc flash hazard by limiting the fault current to a sufficiently low level that the arc cannot re-strike and self-extinguishes. The presentation will highlight and discuss advances in HRG technology that shortens the time required to locate a ground fault, that provides fail-safe protection from ground faults, that allows for process continuity of critical processes even under second fault conditions and finally the option to manage individual feeder protection. Other technologies highlighted will be arc mitigation as well as engineering controls such as arc resistant switchgear, infra-red windows and remote actuators for circuit breakers.
Register for this ON DEMAND Event Today!
Keynote speaker
Daleep Mohla
Principal Consultant
DCM Electrical Consulting Services, Inc
Mike Eby
Editor-in-Chief
EC&M
Discuss this Event 7
Jovita (not verified)
on Apr 5, 2013
Hi, I'd like to know about how long you anticipate the webinar to be?
on Apr 8, 2013
The webinar will run for 60 minutes.
Drewman (not verified)
on Apr 24, 2013
Morning, I'd like to see more info on Arc Flash and PPE requirements.
Anonymous (not verified)
on May 9, 2013
For those of us who can't clear our schedules for this presentation, will this be available as a "play on demand" or will it be offered again soon?
on Oct 28, 2013
Yes, the event is now available in an On Demand format. You can sign up as normal and view it whenever you have the time.
on Oct 28, 2013
Are these ON DEMAND lessons available to watch, since they have show dates have past?
on Oct 28, 2013
Yes, you can still view the On Demand events up to one year after the original delivery date.
Please or Register to post comments.
Event Contact
Upcoming Events
RSS
Sponsored Introduction Continue on to (or wait seconds) ×
