NEMA Publishes Standard for Solid State Light Sources Used in Roadway and Area Lighting
Rosslyn, Va.-based National Electrical Manufacturers Association (NEMA) has published ANSI C136.37, "Solid State Light Sources Used in Roadway and Area Lighting" The first solid state lighting (SSL) standard produced by ANSI accredited standards committee C136.37, this standard defines interchangeability and some requirements for SSL source fixtures (also referred to as luminaires and LED or light-emitting diode fixtures).
Rosslyn, Va.-based National Electrical Manufacturers Association (NEMA) has published ANSI C136.37, "Solid State Light Sources Used in Roadway and Area Lighting."
The first solid state lighting (SSL) standard produced by ANSI-accredited standards committee C136.37, this standard defines interchangeability and some requirements for SSL source fixtures (also referred to as luminaires and LED or light-emitting diode fixtures). References to existing regional and international SSL standards are used to recommend guidance to utilities and manufacturers for harmonized solutions and expectations. C136.37 includes requirements for operating temperature, correlated color temperature, mounting provisions, dimming, ingress protection, and wiring and grounding. In addition, C136.37 sets protocol for surge-test waveforms, the basic insulation test, and specific product ratings.
The contents and scope of C136.37 may be viewed at http://www.nema.org/stds/C136-37.cfm. A hard or electronic copy may be purchased for $52 by visiting global.ihs.com or by contacting IHS at 800-854-7179 (U.S. only), 303-397-7956 (international) or 303-397-2740 (fax).
Discuss this Article 0
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Apr. 15, 2013
video
The Westex Difference
Newsletter Signup
Connect With Us
