Lightolier Fire Line Fire-Rated Enclosure
The UL-classified Fireline enclosure provides fireproofing of recessed downlighting applications and helps prevent the spread of heat and flames into the ceiling space. It maintains the 1-hr fire rating of L500 series ceiling assemblies where recessed lighting is used. The enclosure is constructed of Albi DriCald material and it’s available in three sizes, including an enclosure to fit 2 x 6 wooden
The UL-classified Fireline enclosure provides fireproofing of recessed downlighting applications and helps prevent the spread of heat and flames into the ceiling space. It maintains the 1-hr fire rating of L500 series ceiling assemblies where recessed lighting is used. The enclosure is constructed of Albi DriCald material and it’s available in three sizes, including an enclosure to fit 2 x 6 wooden construction.
