Explosionproof seal
Explosionproof seal The Chico SpeedSeal Compound allows users to install an explosionproof seal in less than 5 min with a three-step process. The compound comes in a pre-measured, self-contained applicator, eliminating the need for water or extra mixing containers. Just pump to mix, inject the pre-measured amount, replace the plug, and the fitting is sealed. It is UL and cUL Listed for use with fittings
Explosionproof seal
The Chico SpeedSeal Compound allows users to install an explosionproof seal in less than 5 min with a three-step process. The compound comes in a pre-measured, self-contained applicator, eliminating the need for water or extra mixing containers. Just pump to mix, inject the pre-measured amount, replace the plug, and the fitting is sealed. It is UL and cUL Listed for use with fittings as large as 2 in.
Cooper Crouse-Hinds
For more information, visit www.crouse-hinds.com.
Discuss this Article 0
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Apr. 15, 2013
video
The Westex Difference
Newsletter Signup
Connect With Us
