Erico Caddy Cablecat
The Caddy Cablecat CAT-CM cable support system is an alternative to a cable tray in low-voltage and power cable applications. The system, which has three installation options, is complete with U-hooks and double J-hooks that have large-diameter, rounded support surfaces and edges to avoid over-bending and kinking of cables. Rod-mounted installation allows for a customized interval between hooks. Cantilever-mounting
The Caddy Cablecat CAT-CM cable support system is an alternative to a cable tray in low-voltage and power cable applications. The system, which has three installation options, is complete with U-hooks and double J-hooks that have large-diameter, rounded support surfaces and edges to avoid over-bending and kinking of cables. Rod-mounted installation allows for a customized interval between hooks. Cantilever-mounting consists of U-hooks mounted on brackets that allow for cable runs along walls or columns. Strut-mounted installation uses standard-strut, contains sheet-metal U hooks, allows for customized support spacing, and has fittings for horizontal and vertical change of direction.
Discuss this Article 0
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Apr. 15, 2013
video
The Westex Difference
Newsletter Signup
Connect With Us
