EC&M Product of the Week
Electrical tester Users of the CMT-80 multi-function meter need not select a measurement function because the device is equipped with an automatic selection feature that chooses from current, voltage, and resistance. Approved for CAT III 600V applications, the meter is designed with a low-impedance input to minimize ghost voltage. It measures AC/DC voltage, resistance, continuity, and AC amperage.
Electrical tester
Users of the CMT-80 multi-function meter need not select a measurement function because the device is equipped with an automatic selection feature that chooses from current, voltage, and resistance. Approved for CAT III 600V applications, the meter is designed with a low-impedance input to minimize ghost voltage. It measures AC/DC voltage, resistance, continuity, and AC amperage. It’s also equipped with a data hold feature that allows the end-user to capture and save important readings. The tester is UL-3111-1 approved.
Greenlee Textron
For more information, visit www.greenlee.textron.com.
