Cooper Lighting Sure-Lites UEL Emergency Light
The Sure-Lites UEL emergency light housing is constructed of die-cast aluminum with a clear polycarbonate shield that protect against rain, moisture, cold, corrosion, dust, and vandalism. The light includes a nickel-cadmium battery, self-diagnostics, a photocell laser test, and four torx head tamperproof screws with a center pin reject. Two adjustable 12-WMR16 lamps provide egress coverage for light
The Sure-Lites UEL emergency light housing is constructed of die-cast aluminum with a clear polycarbonate shield that protect against rain, moisture, cold, corrosion, dust, and vandalism. The light includes a nickel-cadmium battery, self-diagnostics, a photocell laser test, and four torx head tamperproof screws with a center pin reject. Two adjustable 12-WMR16 lamps provide egress coverage for light during a power outage. The lamp is UL-Listed for -35°C to 50°C ambient environments.
Discuss this Article 0
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Apr. 15, 2013
video
The Westex Difference
Newsletter Signup
Connect With Us
