Calculator program
The Volts CD-ROM-based electrical calculation program is designed for engineers, electricians, contractors, and maintenance department employees. The program uses 63 NEC tables and specifications to aid in the selection and sizing of electrical devices, current and ground conductors, circuit breakers, transformers, generators, motors and voltage drops. After you input known values for system characteristics like power factor, voltage, and amperage, the program will check them against those Code requirements to make sure you’re specifying the correct conductors and protective devices. Information contained in Volts can be printed from any printer or saved onto a hard drive for future use or reference.
Dolphins Software, Inc.
For more information, visit www.dolphins-software.com.
