Assembly system
Assembly system The ClickAndGo perforated bottom cable tray system is designed for new cable tray installation, inspection, and repair. The fittings come flat and are hand-folded in the field at the time of installation, eliminating the need for costly field fabrication. The cable trays are manufactured from .89-mm galvanized mill carbon steel, in accordance with ASTM 525 G 90 coating specifications.
Assembly system
The ClickAndGo perforated bottom cable tray system is designed for new cable tray installation, inspection, and repair. The fittings come flat and are hand-folded in the field at the time of installation, eliminating the need for costly field fabrication. The cable trays are manufactured from .89-mm galvanized mill carbon steel, in accordance with ASTM 525 G 90 coating specifications. They’re UL classified and designed for field assembly and use in accordance with the National Electrical Code.
Innova Technologies, LLC
For more information, visit www.Click-n-Go.cc.
Discuss this Article 0
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Apr. 15, 2013
video
The Westex Difference
Newsletter Signup
Connect With Us
