Arc-fault circuit interrupter
Find more articles on Arc Flash/Arc Fault
Arc-fault circuit interrupter This AFCI is the size of a common residential circuit breaker and is equipped with a built-in electronic trip indicator. It’s designed to mitigate the effects of arcing faults produced by worn insulation, damaged wire, loose connections, misapplied or damaged appliances, or stressed electrical cords. Incorporating a thermal magnetic circuit breaker with electronics designed
This AFCI is the size of a common residential circuit breaker and is equipped with a built-in electronic trip indicator. It’s designed to mitigate the effects of arcing faults produced by worn insulation, damaged wire, loose connections, misapplied or damaged appliances, or stressed electrical cords. Incorporating a thermal magnetic circuit breaker with electronics designed to recognize and interrupt arc faults, a solenoid flags when an arc is detected. The AFCI also provides thermal, short-circuit, and overload protection.
Siemens Energy & Automation, Inc.
For more information, visit www.sea.siemens.com/reselec/product/rzcbindex.html.
Discuss this Article 0
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Apr. 15, 2013
video
The Westex Difference
Newsletter Signup
Connect With Us
