Troubleshooting PLC Analog Output Modules, Part 1
In our previous two issues, we discussed troubleshooting digital output modules. Troubleshooting analog modules is a bit more complicated, for two reasons
In our previous two issues, we discussed troubleshooting digital output modules. Troubleshooting analog modules is a bit more complicated, for two reasons:
  1. Analog modules aren't on/off, as digital ones are, so there won't be a status light showing the logic state. You have to (in nearly all cases) use a DMM to see what the output level is.
  2. You need to know the range (e.g., 4mA to 20mA) and possibly the scale (e.g., 1 to 1,600 on the PLC register) for this output. Determining this for certain may require walking through a long documentation trail, beginning with the P&IDs. You may need to resolve multiple conflicts of specifications, if this loop has not worked properly before.
Your first step is to verify that the module is the correct one for this control loop — unless this specific module has worked correctly before. Whether it has or not, you need to use a meter to test the module's output versus input.
One verification technique that works well is to simulate the signal from the PLC by forcing the output. This eliminates a long string of variables and simplifies the job in a few other ways versus having one person out in the field simulating an input to the signal transmitter. In our next issue, we'll discuss how to use this PLC force to determine where the problem lies.
