Product Spotlight
Focus on Facility Management Systems
Fire control communicator Equipped with six fully supervised inputs, the model 5104 six-zone fire control communicator provides reporting over an ordinary telephone line. The communicator can be used as a stand-alone unit to monitor sprinkler systems for waterflow, supervisory, and gate valve tamper conditions or incorporated into an existing system as a Slave DACT. It has one Class A (style D) input
Equipped with six fully supervised inputs, the model 5104 six-zone fire control communicator provides reporting over an ordinary telephone line. The communicator can be used as a stand-alone unit to monitor sprinkler systems for waterflow, supervisory, and gate valve tamper conditions or incorporated into an existing system as a Slave DACT. It has one Class A (style D) input and five Class B (style A) inputs and offers fuseless overload protection with automatic reset circuitry and fault indicators. The communicator also has a dual phone line interface that automatically self-tests every 24 hours and sends a report to the central station.
Silent Knight
Circle 301
Strobes and horns/strobes
The SpectrAlert series selectable output wall-mount strobes and horns/strobes feature a voltage-booster design with a more consistent flash bulb voltage. Available in 2-wire or 4-wire configurations, they can operate on either 12V or 24V with no setting required.
System Sensor
Circle 300
Digital dimming system
The ezDALI digital dimming and scene control system uses an open-protocol to provide two-way, individual ballast-level dimming. The system comprises wall-based controllers, a power supply, DALI ballasts, and a communications databus to provide as low as 1% dimming for linear fluorescents and 3% dimming for compact fluorescents. Push-button programming allows users to set up and reconfigure the system without rewiring.
The Watt Stopper
Circle 302
Perimeter security fence
Using fiber optic sensing cable and tripping devices called “mouse trips,” the Fiber Fence 50 kit monitors as much as 1,000 ft of fence line. The trips detect intrusion attempts anywhere along the perimeter, and the system's control unit provides an instant alert when an intruder disturbs the attached cable or fence. The kit includes a rack-mountable or desktop control unit, 1,000 ft of sensing cable, 15 mouse trips, 300 tie wraps, relay outputs for optional remote monitoring, and installation instructions.
Fiber Instrument Sales
Circle 303
Digital time switch
Available in three models, E100P series single-channel digital time switches are housed in a nonmetallic indoor enclosure that deters rust. The E101P has SPST contacts, the E103P is designed for DPST switching, and the E120P is for SPDT switches. The switches feature an LCD, a power outage battery backup, and 30A contacts.
Tork
Circle 304
Audio command center
Designed for the small building market, the FireVoice 25/50 single- or dual-channel emergency voice evacuation control panel can create five custom messages for fire, tornado, evacuation, haz-mat, and non-fire situations. It's suitable as a stand-alone or as an adjunct to most UL-Listed addressable or conventional fire alarm control panels and has full supervision in both the active and standby conditions.
Notifier
Circle 307
Fire alarm control panel
Manufactured with surface-mount technology, the MS-9600 V2 features fire protection technology like maintenance alert, automatic detector test, and sensitivity printout. The panel has an optional digital alarm communicator transmitter, 14.4kbps modem, two additional notification appliance circuits, and a second loop via a signaling line circuit that can support an additional 318 addressable devices.
Fire-Lite Alarms
Circle 306
Camera housing
Available in single and multimode models, the FiberDome camera housing includes an integrated fiber optics module that converts an analog video signal into 8-bit digital video and transmits RS-485/RS-422 data across a single fiber optic connection. The housing can be used with an existing fiber optic network, and it features the SMARTS system, which helps to diagnose connection problems.
GE Infrastructure
Circle 308
Discuss this Article 0
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Apr. 15, 2013
video
The Westex Difference
Newsletter Signup
Connect With Us
