Product Spotlight
April 1, 2002
Lighting zonal cavity calculator The PocketAGI is an interior lighting zonal cavity calculator program designed for Palm-OS handheld digital assistants. It allows you to select a photometric file, enter room details and desired light level, and produce estimates. It ships with a desktop companion that allows you to build photometric databases and print PDA-generated output.Lighting Analysts Circle
Lighting Analysts
Circle 306
Wall pack fixture for hazardous areas
The SpecOne CPMV series Champ-Pak wall pack luminaire can be used in hazardous areas, including environments that require Marine, NEMA 4X, or IP66/67 ratings. It's available in high-pressure sodium, mercury vapor, metal halide, fluorescent, and induction lamp versions.
Cooper Crouse-Hinds
Circle 302
Floodlight for medium and large areas
The Areamaster 250/400 is a multipurpose floodlight that can be used with high-pressure sodium, metal halide, and mercury vapor lamps. It can be mounted to a pole or yoke. Its lens is made of thermal-shock, impact-resistant glass.
Appleton
Circle 301
HID fixture service kits
Val-U-Pak Plus HID fixture service kits include a core-and-coil HID ballast, system-matched HID lamp, capacitor and ignitor, and mounting hardware and instructions. Kits are available for popular HID lamps, and feature 5-TAP ballasts (120V, 208V, 240V, 277V, and 480V) for most applications.
Advance Transformer
Circle 300
Emergency and security lighting
This fixture provides low-level lighting, including security lighting when main lighting is off and emergency lighting during power failures. It's available in two styles: The 30-PCEM model has two 13PL lamps, and the 80-PCEM has two 42PLT lamps.
W.F. Harris Lighting
Circle 319
Lighting control system
The Dimensions D3200 series of controllers/dimmers offers eight scene buttons for a total of 32 scenes and access to as many as 186 zones. They feature an IR receiver that can be programmed to work with handheld IR controllers. The D3208 offers the same features as the D3206 with 62 additional zones and scheduled scene changes.
Leviton Mfg.
Circle 320
EC&M Staff
