Product Spotlight
Temporary power distribution center The Model 1066 temporary power distribution center has six 5-20R outlets each with overload and Class A GFCI protection, and one L6-30R outlet with overload protection. The Input Power Diagnostic Module constantly monitors the condition of incoming power. Ericson Mfg. Circle 300 Rear-connected Switchboards The QED-6 rear-connected switchboards with Masterpact NW
Ericson Mfg.
Circle 300
The QED-6 rear-connected switchboards with Masterpact NW circuit breakers are UL-489-listed and have a small, flexible footprint with segregated front access to all wiring. The low-voltage switchboards have high interrupting and withstand ratings. The trip units communicate over open protocols.
Square D
Circle 301
Power distribution unit
This 75kVA to 300kVA power distribution unit (PDU) is designed for use with this company’s Silcon Delta Conversion Online technology series of UPSs. Together, the Silcon series and the PDU can protect and manage power for Internet infrastructure, data center, and enterprise applications.
American Power Conversion
Circle 302
Switchboard case for power meters
The Ion 7300, Ion 7330, and Ion 7350 power meters can now be equipped with an optional switchboard case. With this option, the meter comes prewired within a metal frame with a control panel and LCD display mounted in its removable front cover.
Power Measurement
Circle 303
Load center
The UL-listed Ultimate Load Center is an ergonomic unit that can eliminate repetitive-motion work, reducing the risk of repeated-trauma injuries. The ready-to-wire Insta-Wire circuit breaker screws eliminate the need to back out screws before inserting wire. Neutrals and grounds provide quick neutral conductor installation.
Siemens Energy & Automation
Circle 304
Vacuum reclosers
Viper solid dielectric vacuum reclosers are electronically controlled, automatic units. The lightweight, 3-phase units provide bushings on the front and top of the recloser tank. Other features include EPOX solid insulation, a magnetic actuator, and a manual open and lockout handle.
G&W Electric Company
Circle 306
Discuss this Article 0
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Apr. 15, 2013
video
The Westex Difference
Newsletter Signup
Connect With Us
