Product Spotlight
Portable insulation leakage meter The portable Model VMT15 high-voltage Megmeter is a battery-powered HVDC source and meter. It can withstand testing of insulation up to 42kVDC, as well as measure leakage current as low as 0.001 mA and resistance as high as 30-million megohms.Ross EngineeringCircle 300 Diagnostic tool The Allen-Bradley MediaChecker is a hand-held diagnostic tool that analyzes the
Ross Engineering
Circle 300
Diagnostic tool
The Allen-Bradley MediaChecker is a hand-held diagnostic tool that analyzes the physical media of industrial communications networks. It works with all the open networks in this company's NetLinx architecture — including DeviceNet, ControlNet, and EtherNet/IP — as well as Data Highway Plus and Remote I/O networks.
Rockwell Automation
Circle 304
Fiber optic power meters
Models FO600 and FO610 fiber optic power meters measure over a wide 75-dB dynamic range with ±0.15-dB accuracy and 0.01-dB resolution. The FO600 measures from +5dBm to -70dBm. The F610 measures from +25dBm to -50dBm, making it suitable for direct measurements of laser output power.
Extech
Circle 305
Three-phase power meter
The ION 6200 3-phase power and energy meter offers a clear readout on a big LED display. It is 4 in. wide and 2 in. deep, and offers Modbus support. You can add new features in seconds by attaching the company's plug-in feature packs.
Power Measurement
Circle 301
480V energy meter
The Powerlogic 480V energy meter suits commercial and industrial submetering projects, including residential and commercial multitenant facilities, strip malls, and stadiums. It provides cost-effective solutions for monitoring 240V to 480V applications.
Square D
Circle 303
Portable AC power source
Compact and lightweight, the 801P portable AC power source offers continuously variable voltage and frequency, current measurement and limit, and programmability. It delivers 810VA of AC power at any combination of utility voltage and frequency. The 500-Hz upper frequency range supports 400-Hz avionics applications.
California Instruments
Circle 302
Thermal imaging system
The ThermaCAM PM 695 automated infrared (IR) inspection system is a hand-held IR camera that features both thermal and visual imaging capabilities. Ruggedly designed, it quickly records and stores temperature analysis data and voice and text comments with thermal and visual images.
FLIR Systems
Circle 306
