Product News
High-visibility enclosures Vu-Line is an enclosure system that can be configured with as many as three Plexiglas doors, with solid side panels, or with a combination of the two. You can rack equipment on upright 19-, 23-, or 24-in.-wide rails with standard EIA spacing. You can also display equipment on shelving within the cabinet.Premier Metal ProductsCircle 196 Data transfer port lock The Opti-Lock
Circle 196
The Opti-Lock protects optical data transfer ports, preventing unauthorized access to metering data and safeguarding ports from the environment. A company name or logo may be stamped onto the lock. The lock is easy to install and seal with long-term, demand, or cable lock seals.
Ekstrom Industries
Circle 186
Collocation blocks
The HighBand 10 Collocation Blocks are available in kits of 200 or 300 pairs. The blocks provide Cat. 5e compliance and a 45°-angle silver-plated contact. The 10-pair increment of the blocks simplifies matching cables of 50, 100, 300, or greater pairs.
KRONE
Circle 177
Cabling system
This cabling system can replace or enhance cable trays. You snap the nut anywhere on a ¼-in. or ⅜-in. threaded rod. The system is noncorrosive and nonconductive. It supports cable, pipe, or conduit, and holds up to 35 pieces of Cat. 5 cabling.
L.H. Dottie
Circle 194
Cabling section system
The MCS Master Cabling Section System provides a vertical pathway for organizing, distributing, storing, and concealing communications cable between or adjacent to this company's racks. The sections are available in single- or double-sided styles; in a variety of widths and heights; and with a clear or black finish.
Chatsworth Products
Circle 176
Fiber optic power meter
The DM3000 is a dual channel, high-performance fiber optic power meter that offers user customization and data logging in a portable, hand-held package. Its two detectors can measure the loss of two fibers for link testing or for simultaneously monitoring reference and measurement power.
fotec
Circle 168
Rack enclosure
The SR-40-22 floor mount swinging rack enclosure is EIA compliant, provides 40 rack spaces, and can accommodate 350 lb of equipment.
DataTel
Circle 150
Discuss this Article 0
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Apr. 15, 2013
video
The Westex Difference
Newsletter Signup
Connect With Us
