Product News
Oct. 1, 2007
PoE modules These UL-approved industrial-strength Power-over-Ethernet (PoE) modules make it possible to use the Ethernet to transfer both data and electricity. The FL IF 2PSE-F module features two PoE ports for the modular managed switch (MMS). Depending on specific requirements, users can freely combine 8-24 ports in twisted pair, PoE, and various glass fiber media. The FL PSE 2TX module is a compact,
PoE modules
These UL-approved industrial-strength Power-over-Ethernet (PoE) modules make it possible to use the Ethernet to transfer both data and electricity. The FL IF 2PSE-F module features two PoE ports for the modular managed switch (MMS). Depending on specific requirements, users can freely combine 8-24 ports in twisted pair, PoE, and various glass fiber media. The FL PSE 2TX module is a compact, stand-alone solution that converts two standard Ethernet ports into PoE ports. The module generates the 48V power supply required by IEEE802.af PoE from a 24VDC connection.
Phoenix Contact
Circle 200
Exit signage
Tuff-Act exit signage is wet/damp location listed from -40°F (-40°C) to 113°F (45°C). Energy Star-rated, the sign is available in AC-only and self-powered models. In addition, the device features Intelli-Charge self-testing diagnostics electronics for continuous monitoring of critical functions and fulfillment of the monthly periodic testing requirements in NFPA 101 and the IBC. Additional product features include die-cast aluminum housing with impact-resistant, injection-molded polycarbonate covers. According to the company, the maintenance-free, sealed nickel cadmium battery provides 120 min of emergency power.
Chloride, a Genlyte Co.
Circle 202
Monitoring/alternating relays
According to the company, these monitoring and alternating relays can be customized to meet unique application parameters, including fixed settings, remote adjustments, and special pin configurations. For phase monitoring, the D65 series provides protection against voltage faults on 3-phase systems. The D65V series monitors AC single-phase (50/60 Hz) or DC voltages, while the D65C series monitors AC single-phase currents for over- or undercurrent conditions in three ranges: 0.1-1.0A, 0.5-5.0A, and 1-10A. In addition, the D85 series equalizes the run time of two loads through the use of control switches.
Eaton
Circle 204
Floor boxes
These floor boxes provide support for both line-voltage and low-voltage connections. Available in a variety of round and rectangular styles, including single- or two-gang applications, the boxes can be installed in wood, concrete, and ceramic tile. Swing-bracket mounting installs without drilling for mounting screws. Additional product features include an extra-deep design, four knockout wire entries, and two auto-clamp entries. In addition, they are scrub water compliant without caulking and feature a heavy-gauge, die-cast cover plate.
Pass & Seymour/Legrand
Circle 201
freeproductinfo.net/ecm
Fire alarm power supplies
The HP-ULM series, HP-ACM series, and HP-ULPD series provide continuous power for fire alarm accessory operation, including fire door locks, fan shutdown, elevator recall, and magnetic door holders. Delivering 2.5A, 4A, or 6A of continuous power, each unit features electronically regulated and field-selectable 12VDC or 24VDC output that is fully filtered, as well as an automatic switchover to standby battery should AC power fail. Other product features include enlarged enclosures, jumpers, and DIP switches — and rapid serviceability through LED diagnostic indicators.
Honeywell Power Products
Circle 203
Lamp ballast package
According to the company, the UltraStart WattMiser T5 system offers the industry's lowest overall wattage: 216W vs. 234W, which equates to more than $54 in energy savings per fixture over the life of the lamp. In addition, the system incorporates parallel lamp operation that allows the other lamps to remain lit if one fails. With a 0.7 sec start time, there are no delays associated with the use of occupancy sensors and/or lighting controls.
GE Lighting
Circle 205
Portable GFI cord sets
These 15A in-line cord sets are available in single and triple-tap configurations. NEMA 3R rated, the cord sets are for use both indoors and outdoors. A bright LED indicator provides power and fault status, while recessed test and reset buttons help avoid accidental actuation during handling and use. The products are offered with either automatic reset or manual reset, both of which meet OSHA requirements for open neutral protection.
Bryant
Circle 206
Ultrasonic sensors
Microset self-adjusting ultrasonic designer ceiling sensors can be used individually or in combination to provide lighting control and integration with HVAC control throughout a building. According to the company, the sensors require no adjustments for time delay or sensitivity after installation. Available in one-way 180° and two-way 360° models, they are designed for use in rooms ranging from 500 sq ft to 2,000 sq ft. Up to five sensors can be powered from one Novitas switch pack.
Cooper Wiring Devices
Circle 208
Disconnect enclosures
The NEMA 12-rated SDN 12 series of single-door wall-mount disconnect enclosures is constructed of 14-gauge steel bodies and doors with plasma-welded seams. According to the company, the enclosures' poured-in-place polyurethane seamless gaskets provide watertight and dustproof seals. In addition, the products are equipped with a ground stud in the door and collar studs for mounting optional panels. Available options include units with or without padlocking, defeater handle, and latching systems.
Automation Direct
Circle 210
Motor protector
The enhanced 369 motor protection system delivers advanced motor health diagnostics, graphical and data-rich fault diagnostics, six-step setup and configuration, and complete trace d enhanced through the 40-character display with increased viewing angle.
GE Multilin
Circle 207
Expansion fittings
Type AXB expansion fittings are designed for long conduit runs installed in areas subject to vandalism, theft, harsh weather, and extreme temperature variations. Their internal bonding jumper eliminates the need for an external jumper. In addition, the product's outer casing slides open to view the jumper for no-tools-required field inspection. Watertight and corrosion-resistant, the hot-dipped galvanized outer casing is available in trade sizes from ½ in. through 2 in. with 4-in. and 8-in. movement.
O-Z/Gedney
Circle 209
Integrated power center
The expanded line of Square D Integrated Power Center 2 (IPC2) now includes freestanding, front-, and rear-aligned equipment available in multiple enclosure operation, including NEMA 1, NEMA 1 with drip hood, and NEMA 3R. Each unit section measures 91.5 in. high, with widths ranging from 24 in. to 48 in. and depths of either 24 in. or 36 in., depending on section configurations. In addition, each section comes standard with a UL 891 deadfront switchboard, panelboard with door-in-door construction, and factory-installed power cables.
Schneider Electric
Circle 211
