Product News
Rotary switches
Designed to withstand shock, vibration, and other severe conditions, these snap-action rotary switches have double-wiping, low-resistance contacts that hold their positions inside fully enclosed decks and deliver DC or AC switching. Available in a variety of models, the switches carry continuous ratings that range from 20A to 200A at 600V and can be configured with as many as four positions and 12 poles. Non-shorting contacts are enclosed in molded phenolic insulating disks, and all models are equipped with four-hole mounts.
Electroswitch
Circle 207
Zone distribution system
The Connexion is a plug-and-play, 20A modular distribution system designed for raised-floor commercial applications. Its zone distribution box can expand from four circuits to 16 circuits as infrastructure requirements change. The system is pre-manufactured and can be installed by a three-person crew in one day to accommodate 15,000 sq. ft.
Hubbell
Circle 202
Connector tool kit
This anaerobic connector tool kit contains an assortment of more than 30 cable preparation tools and cleaning supplies. The kit also comes with assorted polishing equipment, anaerobic adhesive hardener, anaerobic primer, and a universal microscope.
Fiber Instrument Sales
Circle 201
Circuit breaker racking system
The Automatic Remote Racking System allows workers to handle circuit breaker racking operations while remaining well outside of the arc-flash boundary area. A PLC-activated controller is used to initiate the racking operation. Remote racking retrofit systems are designed for medium-voltage switchgears.
Square D/Schneider Electric
Circle 215
Tubular pulse-start lamps
Uni-Form pulse-start, tubular metal-halide lamps are specifically designed for horizontal operation without the need for a position-oriented socket. Available in 200W, 300W, 320W, and 350W, the lamps offer less light pollution, reduced glare, and better light cut-off from the luminaire.
Venture Lighting
Circle 205
Floor box cover assemblies
FloorPort cover assemblies are designed for this company's Resource RFB floor boxes, Walkercell cellular raceway, and Walkerdeck systems. The covers are available in all-metal (die-cast zinc or die-cast aluminum), brushed aluminum, and plated brass finishes. The covers feature TopGuard protection, which prevents water, dirt, and dust from entering power outlets and communications ports.
Wiremold/Legrand
Circle 206
Heat shrinkable markers
Made from heat-shrinkable polyolefin tubing with a 3:1 shrink ratio, ShrinkTrak is a ladder-style marker for wire, cable, and other applications. Its flat surface allows for consistent printing, and it's packaged with a waxed-core dispenser. Anti-static coating on the line reduces static charge build-up in printers.
HellermannTyton
Circle 203
visit freeproductinfo.net/ecm
