Product News
Power-conditioned UPS The ONEAC brand ONePlus Series power-conditioned UPS features a power range of 250VA to 1,000VA and operates in 120V, 60 Hz, or 230V, 50/60Hz environments. According to the company, the unit's isolation transformer eliminates power contaminants and limits let-through to less than V in common mode (N-G) and less than 10V in normal mode (LN). Additional product features include
The ONEAC brand ONePlus Series power-conditioned UPS features a power range of 250VA to 1,000VA and operates in 120V, 60 Hz, or 230V, 50/60Hz environments. According to the company, the unit's isolation transformer eliminates power contaminants and limits let-through to less than ½V in common mode (N-G) and less than 10V in normal mode (LN). Additional product features include user-replaceable battery packs and USB and Serial RS232 ports for communications.
Chloride
Circle 150
Surge protective device
Strikesorb 40-3000, 40-4000, and 40-5000 medium-voltage surge protection devices are comprised of a 40-mm diameter single distribution-grade metal oxide varistor (MOV) disc in an environmentally sealed aluminum housing. The 40-3000 provides a maximum continuous operating voltage (MCOV) of 2.55kV with a rated voltage of 3kV. The device has a nominal discharge current of 10kA and a residual voltage of less than 10kV. The 40-4000 provides an MCOV of 3.4kV with a rated voltage of 4kV, while the 40-5000 has an MCOV of 4.25kV with a rated voltage of 5kV.
Raycap
Circle 151
The All Mode EMA surge protective device (SPD) is a modular parallel transient voltage surge suppressor that provides discreet surge suppression paths for all 10 modes: (L-L, L-N, L-G, N-G). The product also features multi-stage suppression circuits consisting of metal oxide varistors (MOVs). Each surge suppression mode is individually fused and uses circuitry with thermal cutouts to isolate the SPD and ensure shutdown in the event of MOV damage during severe overvoltages.
Surelogic
Circle 152
freeproductinfo.net/ecm
Discuss this Article 0
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Apr. 15, 2013
video
The Westex Difference
Newsletter Signup
Connect With Us
