Product News
Feb. 1, 2008
Plenum-rated products Chicago plenum-rated downlights have been designed with the City of Chicago's Electrical Code in mind. Product features include liquid-tight conduit that connects the socket cup to the junction box as well as a ballast that sits on the visible side of the junction box. In addition, fixture size has been decreased by in. to 1 in. in overall height.PrescoliteCircle 250 Video monitoring
Chicago plenum-rated downlights have been designed with the City of Chicago's Electrical Code in mind. Product features include liquid-tight conduit that connects the socket cup to the junction box as well as a ballast that sits on the visible side of the junction box. In addition, fixture size has been decreased by ¾ in. to 1⅝ in. in overall height.
Prescolite
Circle 250
Video monitoring system
The IP Quad Module allows users to view high-quality color output from the company's video monitoring system on any home television or over the Internet. The system consists of an indoor and outdoor camera that connects through the company's Structured Media Center. The indoor camera is available with both clear and tinted lens covers. The outdoor camera and included wallplate assembly are available in white and can be painted to match exterior trim. In addition, the outdoor camera includes a separate power supply for applications where cable runs exceed 328 ft.
Leviton
Circle 251
freeproductinfo.net/ecm
Conduit bodies
These combination conduit bodies are for use with EMT and rigid conduit. Constructed of rugged, copper-free aluminum, the combination bodies feature a threaded interior for rigid applications and set screws for use with EMT. UL-listed and UL-listed raintight when used with rigid conduit, the units are available in type C, type LB, type LL, type LR, and type T in trade sizes up to 2 in. In addition, they come pre-assembled with cover and gasket.
Bridgeport Fittings
Circle 252
Drill bits
This line of Rock Carbide SDS Plus drill bits includes four-flute, two-cutter bits ranging from 5/32 in. to 1⅛ in. According to the company, the bits feature a carbide tip that is 10% thicker than comparable products, as well as a thicker core diameter. Also included in the product line are four-flute, four-cutter bits ranging from 5/32 in. to 1⅛ in. The company says the bits' open head design on the four cutter allows debris to early flow into the flute and out of the hole. For increased speed, the bits are also equipped with an elongated four-flute helix.
DeWalt
Circle 253
Dimmers
Harmony dimmers combine an ergonomic on/off paddle switch with a separate slide control. According to the company, constant memory restores the previous lighting level after a power outage. Available in incandescent and magnetic low-voltage versions, the dimmers offer ratings of 700W, 1,100W, 700VA, and 1,100VA. Color options include ivory, light almond, white, black, and brown.
Pass & Seymour/Legrand
Circle 254
Dimmer
The Arabella digital fade dimmer allows 30 sec for users to cross a room before the lights fade to off. To activate, simply press the on/off button until the dimmer's LED flashes and then release. In addition, the LED serves as an indicator of a room's current light level. The product line also includes companion digital switches. Dimmers are available to serve incandescent/halogen and magnetic low-voltage, single-pole/multi-location controls. According to the company, up to nine companion switches can be used with one multi-location dimmer and/or up to nine companion switches with one multi-location switch.
Lutron Electronics
Circle 255
Molded cover
The Terminal Block Cover is an insulated, pliable, plastic molded cover that enhances safety when working on high-voltage terminals. Available in red or black, the company says the device reduces outage durations. In addition, it provides high insulation, extreme temperature resistance, and substantial UV protection.
InsulBoot
Circle 256
Crimper
This ergonomic ratchet crimp tool features four crimp stations, ranging from 22 gauge to 8 gauge. The tool's color-coded crimp nests allow users to quickly match the correct terminal. According to the company, the mating mechanism on the tool prevents the jaw from slipping or misalignments. Additional product features include an elongated handle and a release switch near the handle. Designed for heat-shrink terminals, the tool can also be used for standard insulated terminals.
Del City
Circle 257
Drill bits
These extra-long bell hanger/installer drill bits are designed for deep drilling and wire pulling applications. According to the company, the bits feature a 3-flat shank that enhances the bit's grip and reduces slipping in three-jaw chucks. Available in 12-in., 18-in., and 24-in. lengths with ¼-in., 5/16-in., ⅜-in., and ½-in. diameters, they also feature an eyehole in the flutes, a 118° point, and high-speed steel construction.
Bosch Power Tools and Accessories
Circle 258
Pigtail adapters
The ACO-1000 line of pigtail adapters includes 900kcmil compacted aluminum conductor. Manufactured from high-strength aluminum alloy, the product's off center pin allows connectors to be rotated for parallel applications. In addition, it is UL-listed and CSA certified with a wire range of 1000kcmil to 2/0.
Ilsco
Circle 259
Panelboard skirt/wireway
Designed for indoor use, this surface-mount panelboard/skirt mates with the panelboard, creating a wireway for the cable entry. When the end of the panelboard is removed, it creates a conduit-free path. Constructed of G90 galvanized steel, the unit's CRS cover is painted ANSI 49 or 61 gray. Other product features include strain relief brackets and no holes or knockouts.
Metal Cabinet and Fixture
Circle 260
