Product News
Generator self-test verifier The GSV300 generator self-test verifier now features an LCD display that provides details about critical system tests, including exercise failure, generator start failure, and runaway, as well as battery and oil replacement reminders. In addition, the product gives users information on total run time, countdown to the next exercise cycle, the number of good and bad runs,
The GSV300 generator self-test verifier now features an LCD display that provides details about critical system tests, including exercise failure, generator start failure, and runaway, as well as battery and oil replacement reminders. In addition, the product gives users information on total run time, countdown to the next exercise cycle, the number of good and bad runs, and the voltage and frequency.
Transtar Products
Circle 200
Emergency light
The Rhyno Series emergency luminaire features a 120/277V input with surge protection and Intelli-Charge for self-diagnostics. Available in 6V, 12V, and 24V, 25W to 100W, the light is resistant to liquid, moisture, dirt, and dust. Other product features include an impact-resistant housing, corrosion-resistant hardware, and a one-piece molded gasket. Two lamp heads are internally mounted on the bottom and are held in a fully adjustable molded swivel assembly. The product is supplied with a wall-mount bracket, but can also be column, pole, or I-beam mounted. Users can choose from a maintenance-free sealed lead-calcium, pure lead, or nickel-cadmium battery that offers a minimum of 90 min of emergency power, according to the company.
Chloride, a Genlyte Co.
Circle 201freeproductinfo.net/ecm
LED dimmer
This DC-DC dimmer for LED lighting products supports 5VDC to 40VDC applications up to 2A or 24W. According to the company, the product's LED dimming range is 0% to 100% of input. In addition, dimmer output is continuously adjustable between zero and full-on. Able to drive up to 2,000 standard white discrete LEDs or 50 high-flux LEDs, the dimmer operates on minimal no-load current of 10mA to 15mA. Measuring 2.3 in. × 1.9 in. × 1.1 in., the product comes in an industry-standard hockey puck package design.
LEDtronics
Circle 202
Voltage quality recorder
The VR1710 is a single-phase plug-in voltage quality recorder. According to the company, the product records data specified by a user-selected average period on voltage trends, dropouts, and power quality parameters, including rms average, transients, flicker, and harmonics up to the 32nd. Able to plug directly into the mains power socket, the recorder also includes a USB cable and PowerLog software featuring tools for data presentation.
Fluke
Circle 203
Lighting controller
The LI-ARP lighting control system provides two relay outputs to support bi-level switching and manual-on operation. In addition, the system is equipped to accept inputs from occupancy sensors and daylighting controls. By providing terminations for the loads as well as for the control inputs, the device eliminates multiple runs of line voltage and control wiring back to a central panel location. In addition, users can optimize the electrical system by feeding multiple relay packs from a single circuit breaker, fully loading each circuit.
Watt Stopper/Legrand
Circle 204
Work gloves
Journeyman work gloves are offered in utility, framer, heavy-duty protection, and leather work versions. Made of professional-grade, genuine goatskin leather, the gloves feature two-way form-fitting spandex on top, rubber grips on the back of the hand and fingers, a lightly padded palm, an elastic cuff, and foam padding on the knuckles. Users can choose from medium, large, and extra-large sizes.
Klein Tools
Circle 205
Wire tap/splice
This insulation displacement contact (IDC) poke-in wire tape/splice allows for quick termination to the “run” connection. The product is available in two sizes. One size accepts 12 AWG solid or stranded wire, and the second size accepts 18 AWG solid or stranded wire. In addition, the power tap for each size accepts 18 AWG pre-stripped solid wire. Contact current rating is 7A with an operating voltage of 600V maximum, the housing is UL 94V-0 thermoplastic, and the contact material is copper alloy.
Tyco Electronics
Circle 206
Power/light cord reels
Series LG medium-duty industrial power and light cord reels are constructed of high impact-resistant composite materials and are lighter and more compact than steel reels, according to the company. Able to accommodate up to 50-ft lengths of 16/3, 14/3, and 12/3 diameter cable, the reels feature an adjustable cable stop and a circuit breaker that can be reset. In addition, they can be mounted overhead, on a wall, or detached from their mounting brackets for portability.
Reelcraft
Circle 207
Electrical receptacles
Available in hospital and specification grade, the SNAPConnect electrical receptacle system features a pre-wired terminal that is installed at rough-in. According to the company, the system saves more than 3 min total installation time per device compared to a conventionally wired duplex. In addition, the system's pre-stripped leads eliminate the need to make pigtails.
Hubbell Wiring Device-Kellems
Circle 208
Ground bars
These ground bars now include low-profile tamper-resistant stainless steel hardware to reduce incidents of theft. UL-listed, the ground bars are manufactured from electrolytic tough pitch 110 alloy copper.
Harger Lightning & Grounding
Circle 206
UPS software
SoftScale offers a software-based approach to UPS scalability. The product allows users to purchase the UPS capacity they need today while providing the ability to unlock additional capacity in the future through a software download. Systems will scale from 40kVA to 80kVA or from 80kVA to 120kVA, in 20kVA increments. SoftScale is enabled by advances in UPS design, which optimize the UPS efficiency curve. This allows the UPS to operate with the same high efficiency at 50% as it does at 100%, eliminating penalties of operating a UPS at a reduced load.
Emerson Network Power
Circle 207
