Product News
The latest products from around the industry
Manual transfer switches The PowerStay Models 2026 and 3028 are prewired manual transfer switches that are UL listed and meet the requirements of Art. 702.6 of the NEC. The 2026 includes six circuits, 20A, for generators up to 5,000W and is expandable to 10 circuits. The 3028 model has eight circuits, 30A, for generators up to 7,500W and is also expandable to 10 circuits. These models are offered
The PowerStay Models 2026 and 3028 are prewired manual transfer switches that are UL listed and meet the requirements of Art. 702.6 of the NEC. The 2026 includes six circuits, 20A, for generators up to 5,000W and is expandable to 10 circuits. The 3028 model has eight circuits, 30A, for generators up to 7,500W and is also expandable to 10 circuits. These models are offered in a kit packaged with a heavy-duty generator cord and a power inlet box enclosure.
GenTran
Circle 250
Dimmable LED fixture
The BV independently dimmable LED fixture fits into normal wall depth for both new construction and remodeling work. The fixture, which is field paintable, features a screwless faceplate in black, gray, or white. It can be fed with a 120V, 240V, 277V, 12V battery, or low-voltage remote transformer and may be daisy-chained. The 6.4 in. × 3.2 in. × 3.5 in. fixture is designed for indoor use, including damp locations. It comes with either a clear or frosted lens and is available in an assortment of LED colors, including warm (3,500K) and cool (5,000+K) white.
Gemini One Five Luminaires
Circle 251
Cordless power tools
This company's cordless 36-V power tool product line is designed to provide two times more power and two to three times more runtime than 18-V tools. The seven-tool product line includes a hammerdrill, reciprocating saw, circular saw, impact wrench, rotary hammer, jigsaw, flashlight, and combo kits. The tools use new lithium-ion batteries that purportedly provide a high-level of power, durability, and life when compared to conventional lithium batteries.
DeWalt
Circle 257
Main breaker device
This new Square D 2,000A EZM main breaker device is designed to meet expanded service amp ratings with a single unit. The device uses the company's PowerPact R-frame circuit breaker. Its split main cover locks with stainless steel hasps, and a separate access door for the main breaker handle allows access without removing the main cover. It can be used wherever 240VAC maximum multi-metering is specified and requires branch devices with 1,200A horizontal cross bus. The device is offered in overhead/underground or underground-only models.
Schneider Electric
Circle 252
Prewired receptacles and switches
These prewired devices offer one-piece construction and require no additional components to install. Featuring the company's patented ScrewCatch design, which captures the wallplate screw, these units come in various sizes, specification grades, and colors. They are also UL listed and Code compliant.
Cooper Wiring Devices
Circle 254
Wire lead receptacles
The 5262-L and 5362-L industrial wiring devices are wire lead duplex receptacles with three 6-in. 12 AWG THHN wire leads. Both models feature a heavy-gauge, locked-in, wrap-around strap, dual drive pins, and a die-cast center bushing. The receptacle bodies and covers are made of impact-resistant thermoplastic and are available in seven colors. They come in 15A or 20A straight blade models, with 2-pole, 3-wire grounding, and phosphor bronze contacts.
Leviton
Circle 255
Weather protective covers
These die-cast aluminum in-use weather protective covers are designed for use with duplex and GFI receptacles in damp and wet locations outdoors. The covers are available in either a horizontal or vertical design in a gray or a white powder coat finish. They are lockable, UL approved, and come standard with an adhesive-backed gasket and four mounting screws.
Mulberry Metal Products
Circle 256
freeproductinfo.net/ecm
Discuss this Article 0
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Apr. 15, 2013
video
The Westex Difference
Newsletter Signup
Connect With Us
