Product News
LED signage White LED edge-lit Caliber signage offers computer-generated custom graphics and wording to match a user's way-finding or informational needs. Featuring a slim profile and available in numerous finishes, the product accommodates recessed ceiling, surface ceiling, surface end, and surface wall-mount configurations out of one box. IC-rated and listed to UL 48 standards, the product's housing
Sept. 1, 2008
4 min read
LED signage
White LED edge-lit Caliber signage offers computer-generated custom graphics and wording to match a user's way-finding or informational needs. Featuring a slim profile and available in numerous finishes, the product accommodates recessed ceiling, surface ceiling, surface end, and surface wall-mount configurations out of one box. IC-rated and listed to UL 48 standards, the product's housing is constructed of die-cast aluminum, and the panel is manufactured from high-impact acrylic with silk-screened computer-generated artwork.
Chloride
Circle 250
Receptacles
These devices comply with 2008 NEC requirements for weather-, tamper-, and combined weather- and tamper-resistant receptacles. Comprised of engineered plastic and corrosion-resistant metal components, the weather-resistant receptacles offer protection from the elements in residential and commercial outdoor locations when properly installed in an approved weather protective cover. According to the company, the tamper-resistant receptacles feature a UL-listed safety shutter system that allows only 2-prong or 3-prong plugs to be inserted into the outlet. The combined tamper- and weather-resistant receptacles are designed for use in pool and spa areas, patios, decks, basements, garages, and building exteriors.
Cooper Wiring Devices
Circle 251
freeproductinfo.net/ecm
Hard hats/caps
The V-Gard series of caps and hats features a polyethylene shell with the company's 4-point Fas-Trac ratcheting system. Available in head sizes six through eight, this series is offered in white, yellow, and blue shell colors. Featuring cooling vents, the Advance cap includes a Glaregard under its brim to reduce reflective glare. According to the company, lateral contours above the ear allow easy integration of hearing protection. Offered in white, yellow, and blue, this Type 1 helmet meets or exceeds ANSI Z89.1-2003 and CSA Z94.1-2005 specifications for Class C. The Skullgard cap and hat are for use in industries where elevated temperatures are common. Featuring a resin shell with 4-point Fas-Trac ratcheting suspension, the products are offered in a tan color. In addition, they meet or exceed ANSI Z89.1-2003 and CSA Z94.1-2005 for Class G. With a wide brim and Western-style design, the Western Outlaw hat is available in tan and meets or exceeds ANSI Z89.1-2003 and CSA Z94.1-2005 specifications for Class E.
Klein Tools
Circle 252
Luminaire
The Concentric Cylinder ceramic metal-halide (CMH) trac lighting fixture features a computer-contoured faceted reflector mounted to the lamp shroud for precise optical alignment with the lamp, according to the company. In addition, the lamp shroud has a 1-in.-deep integral step baffle for shielding and brightness control. Offered in wattages ranging from 20W to 70W, the fixture is available in the vertical ballast MHV Series and the horizontal ballast MH2 Series.
Juno Lighting
Circle 253
Cable reel
The NSCR700 cable reel features a compact design with a heavy-duty, narrow frame for use with live electrical cable. The product also features a spring motor that provides self-contained rewind power with a non-sparking ratchet assembly that locks the reel when the desired length of cable is payed out. In addition, the reel houses a standard 3-conductor, 45A, 600V collector assembly with No. 8 gauge wiring from the collector ring to the junction box. Able to accommodate 50 ft to 120 ft of 14/3 to 8/3 AWG live electrical cable, the product is equipped with a 4-way adjustable roller assembly. A cable stop is available to prevent roller and connector damage and permit the adjustment of free cable length.
Hannay Reels
Circle 254
Rotary hammer drill
TE 2 and TE 2-S rotary hammer drills are for installation work on concrete and masonry, as well as drilling in metal, wood, and gypsum board or plastic. Weighing 5.3 lb, the TE 2 model performs over the drilling range of 3/16 in. to ¾ in. The TE 2-S features a fine hammering setting that the company says reduces impact energy by approximately 70% while drilling at full speed.
Hilti
Circle 255
Multimedia outlet
The homeSELECT JLOAD multimedia outlet incorporates power, Cat. 5e, and coax in a single unit. In addition to black, the outlet is available in white, almond, light almond, gray, and ivory. The device is also available in a custom configuration, offering one 125V power receptacle with two open ports that can accept the company's snap-in jacks or coax.
Hubbell Wiring Systems
Circle 256
Luminaire
The RSA Combolight is available in 1-, 2-, 3-, 4-, 5-, and 6-lamp linear configurations and a 4-lamp square configuration. Product features include individually removable and interchangeable double-gimbal lamp rings with 45° × 45° aiming and threadless lamp bezels with 45° spill cutoff that can accommodate up to three accessories (two lenses and one snoot or baffle). An optional retractable arm mechanism allows “pull-down” of lamps for enhanced aiming angles. One common housing type accommodates both trim flange and trimless inserts.
Cooper Lighting
Circle 257
Metal box kit
These metal box kits feature the company's pre-installed PlugTail connectors. Ground wire pre-mounted to the box and a factory-installed mud ring are also included in the kits. In addition, they are available in single- and double-gang versions in multiple sizes.
Pass & Seymour/Legrand
Circle 258
