Product News
April 1, 2009
Track fixtures The Vanguard Series of low-wattage ceramic metal-halide and low-voltage track fixtures incorporates the company's Slimline ballasts. Featuring a cool-to-the-touch hot aiming wand for proper optical alignment and adjustable lamps (358 horizontal/180 vertical), the product's die-cast aluminum housing includes an individual on/off switch for easy lamp replacement and a positive vertical
Track fixtures
The Vanguard Series of low-wattage ceramic metal-halide and low-voltage track fixtures incorporates the company's Slimline ballasts. Featuring a cool-to-the-touch hot aiming wand for proper optical alignment and adjustable lamps (358° horizontal/180° vertical), the product's die-cast aluminum housing includes an individual on/off switch for easy lamp replacement and a positive vertical locking mechanism for precise illumination. Available in 10 models, finishes include black, silver, and white. Depending on the model, lamps range from 20W to 75W. Ceramic metal-halide fixtures include MR16, PAR20, PAR30, PAR38, T4, and T6; low-voltage includes AR111 and MR16.
Nora Lighting
Circle 250
CFL downlight
The 8123HAq Series of 6-in., airtight compact fluorescent downlights uses self-ballasted GU24 lamps ranging from 13W to 23W of light output. Available with a variety of popular trim options, product features include captive nails in the preinstalled bar hangers, quick connectors preinstalled in the J-box, and adjustable socket brackets.
Royal Pacific
Circle 251
freeproductinfo.net/ecm
Luminaire disconnect
The 873 Series of LUMI-NUTS luminaire disconnects has been expanded to include the 873-903 3-pole model. Designed for use with linear fluorescent fixtures that use a dimming circuit or DALI protocol, the disconnect offers a rating of 6A, 600V and uses a UL94V-0 flame-rated polyamide 6.6 housing for flame retardation. NEC 410.74(G) compliant, the power input/line side accommodates 18-12 AWG and 16-12 AWG stranded conductors while the ballast/load side accepts 18 AWG solid conductors. In addition, the product features a touchproof design whether mated or unmated, which eliminates the need to disconnect power for service. Other features include an integrated locking latch and keyed and color-coded connectors.
Wago
Circle 252
Wall pack covers
The Light Wraps line of decorative steel wall pack covers is available in three sizes that the company says fit over most standard wall packs. Available with optional Dark Sky kits that provide full top and side light cutoff, the wall packs feature 16 standard interchangeable faceplates and a variety of colors. In addition, users can create their own modified faceplate styles, incorporating laser-cut logos, address, emblems, and more.
DPI
Circle 253
Outdoor luminaires
The Design AF 14/20 Series of outdoor accent and wall wash luminaires features a locking metal faceplate that secures the lens to the metal housing backplate. The half-oval luminaires are available in two sizes with a choice of clear or tempered glass lens that is silicone-sealed to the lens frame or a vandal-resistant clear polycarbonate lens. Additional options include grid, barn door, or visor light shields and a choice of black, bronze, gray, green silver, or custom finishes.
Quality Lighting
Circle 254
On-grid mounting system
The Litecontrol Canopy Box is designed for on-grid mounting of light fixtures with T-bar ceiling installations. Intended for installation in a NEMA Type G grid ceiling with a maximum T-bar height of 1½ in., the canopy box can be installed where fixture hanging cables are located on the main T-bar. Designed for use with 9/16-in. T-bar, 15/16-in. T-bar, and screw-slot T-bar, the product is UL- and cUL-approved.
Litecontrol
Circle 255
Downlight
The Living Systems residential CFL downlight is comprised of a pin-based lamp and ballast. According to the company, the downlight has a 10,000-hr life and reduces energy consumption by up to 75%. Designed to meet Energy Star and California Title 24 building code requirements, the product is available in 16W, 21W, and 28W models. Additional features include enhanced phosphor mix and an intelligent ballast design that senses the lamp wattages and adjusts for optimal performance.
Osram Sylvania
Circle 256
Led luminaire
This second-generation of the Trac 12 TL201LEDX Series features a 1-in. profile, cool-to-the-touch operation, and does not emit UV radiation. According to the company, the luminaire provides approximately 30% more light than the previous generation and features up to a 50,000-hr service life. Additional features include 140° light distribution, field-customizable system length, and a choice of 3,000K or 4,100K color temperatures.
Juno Lighting Group
Circle 257
Lighting controls
The LS Series of lighting and fan speed controls has been expanded to include a decorator slide dual dimmer, a decorator preset dimmer with independent switch, and a preset single-pole 3-way dual fan speed/dimmer. The dual dimmer features two 300W, single-pole slide-to-off dimmers and installs in a single gang box. The preset dimmer with independent switch includes single-pole 3-way preset dimmer and single-pole 3-way switch functions. The dual fan speed/dimmer combines a single-pole 3-way preset dimmer and a single-pole 3-way preset de-hummer fan-speed control. All models feature an optional locator light.
Pass & Seymour/Legrand
Circle 258
Luminaire
The Scilux luminaire is available in two models and features Instaleze, allowing tool-less access to the lamp and ballast compartment. The SCX model measures 32 in. × 20 in. × 13.5 in. and accepts mogul base lamps from 150W to 400W. The SCXM measures 24 in. × 15 in. × 10 in. and uses medium base lamps from 70W to 175W. Both models can be wall- or pole-mounted as a single unit or in clusters up to four fixtures. Constructed from cast aluminum in a choice of dark bronze, black, white, or silver finishes, the product is Dark Sky-compliant and UL-listed for wet locations.
U.S. Architectural Lighting
Circle 259
