Product News
Area light This outdoor LED area light provides up to 60% energy savings compared with traditional HID lamp sources and optical systems, according to the company. With a 50,000-hr planned service interval, the light also provides a 5,500K color temperature, a 70+ color rendering index, and a low-glare optical design.GE Lighting SystemsCircle 200 Wiring devices The Clamp-Lock Series of specification-
Area light
GE Lighting Systems
Circle 200
Wiring devices
The Clamp-Lock Series of specification- and hospital-grade NEMA wiring devices features spring pressure terminals. Available in 15A and 20A straight-blade configurations, the product's design uses color-coded cam levers to open and snap close the chambers that accept the conductors with the press of a finger.
Marinco Electrical Group
Circle 201
freeproductinfo.net/ecm
AC industrial motors
Baldor•Reliance API 547 AC industrial motors meet the American Petroleum Institute's Specification 547 requirements. Available from 250 hp to 3,000 hp in 2-, 4-, 6-, and 8-pole speed configurations, the company says the motors can be manufactured to comply with specific user requirements for critical duty motors.
Baldor Electric
Circle 202
Control panels
IntelliKnight addressable fire alarm control panels support synchronization of system sensory A/V appliances and a USB programming port. UL 9th Edition-listed, the product line consists of three models: the 5700 for smaller applications, the 5805 for medium-size applications, and the 5820XL for larger applications. The 5820XL features a power supply capacity of 6A and a deadfront option that allows for reset, silence, and acknowledge functions without requiring a user code or operator's key.
Silent Knight, a Honeywell Co.
Circle 203
Arc hazard assessment software
ArcPro arc hazard assessment software is designed to aid in the selection of protective clothing by defining the arc hazard for workers who may be accidentally exposed to electrical arcs. The software provides users with calculations, including heat exposure, total heat flux, and heat energy on a surface, at various distances from an electric arc. Users can then specify clothing that will withstand the level of predicted arc hazards.
HD Electric
Circle 204
AC drive
The J1000 AC drive requires 70% less space than traditional AC drives, according to the company. Available from ⅛ hp to 7.5 hp, voltage classes include 200-240V single-phase, 200-240V 3-phase, and 380-480V 3-phase — all of which are 50/60 Hz. Additional product features include open loop V/f control with a speed range of 40-to-1, normal (120% overload for 60 sec) and heavy-duty (150% overload for 60 sec) ratings, starting torque of 150% at 3 Hz, 5-digit LED keypad, increased vibration resistance from 20 Hz to 50 Hz, and a swing PWM function to decrease audible motor noise.
Yaskawa
Circle 205
Downlight
The GS6-CXRE downlight features 16 LEDs with efficacy of up to 93 lumens per watt and with a 50,000-hr service life, according to the company. In addition, the luminaire's 1½-in. LED spacing and heavy-duty heat sinks maintain junction temperatures below 75°C at 25°C ambient. Other product features include drivers and a printed circuit board that are accessible from below the fixture, a quick disconnect plug, optional dimming drivers, and an 18-gauge steel housing. Mercury-free, the product is UL-listed for indoor applications, damp locations, and insulation contact.
Gallium
Circle 206
Insulated tools
These combination insulated tools are designed for both metric and standard applications. Tested to 10,000VAC and rated for 1,000VAC maximum exposure, the tools meet or exceed ASTM F1505-01 and IEC 900 Standards for Insulated Hand Tools. In addition to being impact-resistant and flame-retardant, the product's 2-colored insulation material allows users to know if the tool is no longer properly insulated.
OEL
Circle 207
Uplight
Lightvault in-grade uplight CFLs use low-heat compact fluorescent technology to reduce the temperature of the lens to as low as 50°C, making them suitable for walk-over locations and high-traffic pedestrian areas. Available in 26W, 32W, and 42W models, the product is available with a bronze or composite housing. In addition, the lens gasket is constructed from one-piece molded silicon with U-channel that wraps completely around the lens flange. Other product features include an anti-siphon barrier on wiring to and from the splice compartment, a reverse draft housing to prevent uplifting, and cast bronze or stainless steel lens rings.
Kim Lighting
Circle 208
Alternating relay
The Square D 8501KA Series alternating relay is designed as a direct replacement for competitive alternating plug-in relays used to control multiple loads. Available with several contact and voltage configurations, these socket-compatible products have a top-mounted toggle switch to select the alternating mode applicable to the system. When used with the mating Square D socket, the relays have a UL-listed approval status.
Schneider Electric
Circle 209
Circuit breakers
UL489 DC miniature molded-case circuit breakers are rated at 125V (1 pole) and 250V (2 to 4 poles) up to 63A. With a width of 17.5 mm per pole, the breakers enable service entrance, feeder, or branch circuit protection and disconnect function. In addition, the product design allows for DIN-rail mounting and features a positive trip indicator and a short-circuit interrupt capacity of 10kA. Available accessories include auxiliary switch, shunt trip, and undervoltage trip. Custom breakers can be developed for specific user application requirements.
Altech
Circle 210
Motor protector
The Multilin M60 motor protection system now features remote resistance thermal detector (RTD) support, giving the product the ability to monitor up to 12 RTDs. In addition, the device features embedded IEC 61850 communications and enhanced security features, including Dual Permission Access Control and User Command Logging. The product also offers ambient temperature monitoring and alarming.
GE Digital Energy
Circle 211
Data logger
The Simple Logger II Model L261 is a 600VAC/DC data logger. Product features include extended recording mode, delayed start time, and internal memory that stores more than 240,000 measurements. All AC measurements are true rms, and all DC measurements allow the user to program both scale and engineering units. In addition, the device features a series of front-panel LEDs and includes DataView application software for real-time viewing of measurement data.
AEMC Instruments
Circle 212
