Utility light
Suitable for wet locations, the ProSeries utility light is UV-, high impact- and corrosion-resistant. In addition, the product features the company's 18-cu-in. Octi-Junction Box that provides capacity for an additional power circuit. Eight mounting brackets on the junction box are in line with the ½-in. and ¾-in. trade-size knockouts and eliminate a 2-in. × 4-in. stub-in. Other product features include an optional quarter-turn safety cage that attaches to the junction box without tools, an integrated junction box cover that includes a “captive” set screw and posi-stop detent, and a nickel-plated brass screw shell that resists corrosion and is recessed approximately 1 in. to accommodate high-profile compact fluorescent or incandescent lamps (rated for a 150W incandescent lamp, max.).
Circle 200
Fluorescent luminaires
The XP Series of lighting fixtures is now UL-listed for use in 55ΩC ambient temperature in the 2- and 4-lamp configurations. In addition, the product can be used in applications where the following classifications exist: CI D1 Group C and D; CI D2 Groups A, B, C, and D; CII D1&2 Groups E,F, and G; Class III; UL 1598, 1598A, 844, 924; Nema 3, 4X; and IP66.
AZZ/RAL Rig A Lite
Circle 201
Linear LED luminaires
The Emerge CoveWash low-profile linear LED luminaire features a design that uses a linear parabolic reflector and thin-film diffusers to create various angled beams. Consuming 3W per foot, the unit is available in color temperatures ranging from 2,700K to 6,300K and in 1-ft and 2-ft lengths with flexible end-to-end molded connectors. Enclosed in a 1-in. diameter housing, the product includes a variable angle mounting bracket that allows up to 180° rotation.
Circle 202
Emergency luminaire
The Rhyno Series of luminaires has been expanded to include 12V and 24V, 200W to 450W models. A 120/277 dual-voltage input with surge protection and the company's Intelli-Charge technology for self diagnostics allows the luminaire to act as an emergency lighting unit. Liquid-, moisture-, dirt- and dust-entry resistant, the product has been third-party tested for NEMA 4x and IP66 areas, is NSF-listed, and is UL-listed for wet locations in cold ambient, high ambient, or extreme ambient conditions.
Circle 203
The XPoint relay provides the features of a networked relay but without the panel. The relay can independently control each light fixture or can be mounted at the head of a row of fixtures to control the entire row. According to the company, up to 125 relays can be daisy-chained using Cat. 5 cable with RJ45 connectors back to a router box. Measuring 2.3 in. × 2.6 in. × 2.0 in., the device can be assigned to any one of 48 zones (each router box provides individual control of 48 zones from each of up to six control ports).
Lighting Control & Design
Circle 204
SmartLockPRO GFCI hospital-grade receptacles now feature tamper-resistant (TR) models. Available in 15A and 20A, 125V NEMA straight-blade configurations, color options include ivory, white, red, light almond, and gray. In addition to line-load reversal and end-of-life indication, the product features mechanical shutters that prevent insertion of foreign objects by only accepting a properly rated 2-pronged plug. Other features include an impact-resistant nylon face and enhanced electronics for improved resistance to surges and overvoltages, according to the company.
Circle 205
Outdoor luminaires
The Galaxy Series of outdoor luminaires has been expanded to include 13 additional models with varied heights and requirements, depending on site requirements. Options include interchangeable hood and diffusers in multiple sizes and designs, along with mounting arms in arch, deco, yoke, post top, and swooped styling. In addition, seven light distribution patterns are available with either horizontal or vertical lamps, ranging from 70W to 400W. Finishes include dark bronze, medium bronze, black, white, and aluminum.
U.S. Architectural Lighting
Circle 206
This line of transformers has been increased to 1,000kVA. The transformers also feature a larger wiring area and improved airflow that results in a cooler unit, according to the company. In addition, the 115° and 150° rise models will have the same size enclosure. Identified by the mark “Revision A” on their nameplates, the product's electrical characteristics will remain unchanged.
Jefferson Electric
Circle 207
Landscape luminaire
The FG Series of 12V landscape well lights includes five models with various cover styles, including full view, louvered, round hood, square hood, and vandal-resistant crisscross. Each fixture measures 4¾ in. wide and has a 4½ in. depth. Available in black and bronze, they units are constructed from injection-molded PBT composite. In addition, an adjustable lamp bracket allows users to tilt the lamp ±25°. A 20W MR16 lamp also is available.
Circle 208
Suitable for use in wet or damp environments, the 379 Series luminaire features a fiberglass reinforced housing and closed cell polyurethane gasket with no seams. IP67-rated for indoor and outdoor use in locations with high-pressure hose-down requirements, the product is available in 28W, 32W, 44W, and 54W versions for use with T8, T5, T8HO, and T5HO lamps. In addition, the product's impact-resistant acrylic 91.5% transmission lens features frosted ends, lineal prism sides, and an optically clear face. An optional UV stabilized polycarbonate 87% transmission lens also is available.
LDPI Lighting
Circle 209
Outdoor luminaire
This outdoor luminaire reduces energy consumption by up to 50%, according to the company. Operable in extreme hot and cold temperatures, the unit features mounting brackets for all standard pole mounts and wall mounts. In addition, the angle of the lights can be changed on site.
Orion Energy Systems
Circle 210
The DanaLite DL100 modular LED linear luminaire measures ½ in. high × 1 in. wide. Mercury-free, the unit uses 24VDC input voltage and has a lifespan of more than 50,000 hr, according to the company. Cool to the touch, the product also features low forward-heat throw.
Juno Lighting Group
Circle 211
