Product News
Feb. 1, 2007
Dynamic braking resistors These dynamic breaking resistors can be used with both AC variable-frequency drives and DC drive applications. Rated between 300W and 6,000W, they are mounted in NEMA Type 1 enclosures and are prewired for installation. The enclosure is constructed from aluminum and includes two endplates and a screened cover.Milwaukee ResistorCircle 200 Voltage detector/flashlight The LVD2
Milwaukee Resistor
Circle 200
The LVD2 Volt Light compact pen-style tool combines non-contact voltage detection from 90VAC to 600VAC with a white LED flashlight. Designed for industrial and commercial use, the pocket-sized light is CAT IV 600V rated and features dual levels of detection, glowing blue to indicate proximity within 5 in. to an AC voltage source, and changing to red when it is at the source within 1 in. Operating temperature is 0°C to 50°C.
Fluke
Circle 201
freeproductinfo.net/ecm
Wireless meters
D-Mon Class 4100 wireless KWH meters are for use in multifamily sites, such as apartments, condominiums, and dormitories. According to the company, they allow for accurate and equitable cost allocation of energy costs to tenants, departments, and common areas from almost any location. Data is transmitted wirelessly via built-in transceivers to a central storage gateway, where data can be accessed using the company's AMR software through Ethernet or Internet. UL listed, they meet ANSI C12.1 and C12.16 standards.
E-Mon
Circle 202
Lighting controller
The Square D Powerlink 3000C controller is designed to link the company's Powerlink G3 system and its Clipsal lighting control input devices. With this controller, G3 remotely operated circuit breakers can be commanded to open or close in response to Clipsal input devices. The product features extensive time-scheduling capabilities, peer-to-peer communications, an embedded Web server, and logging and alarm capabilities.
Schneider Electric
Circle 203
Power distribution system
Available in capacities from 15kVA to 300kVA, the Liebert FPC Power Center features local and remote power monitoring capabilities. It is offered in two sizes designed to fit at the end of, or within, a row of racks. The 15kVA to 125kVA is a standard 19-in. rack, while the 150kVA to 300kVA is in a 47-in. cabinet — the size of two 19-in. racks. Features include a compact design, flexible breaker configurations, and full front or rear access.
Emerson Network Power
Circle 204
Diesel generator sets
DSGAx diesel generator sets are rated at 80kW, 100kW, 125kW, and 150kW. EPA Tier-3 compliant, they are suitable for supplying standby or prime power to commercial buildings, hotels, and office complexes. Models DSGAA (100kW), DSGAB (125kW), and DSGAC (150kW) feature a 6-cylinder QSB7 turbocharged charge air-cooled (CAC) diesel engine. The products' pedestal design physically isolates controls and circuit breakers from the vibrating parts, increasing the life of the components in prime power applications.
Cummins Power Generation
Circle 205
Wiring system
The Modex line of modular wiring systems consists of three factory-assembled designs: prewired, pigtailed, and hardwired. UL listed and custom designed to meet specific branch circuit wiring specifications, they are intended for device-intensive building applications, such as hotels, condominiums, dormitories, apartments, and hospitals.
Alcan
Circle 206
Power distribution unit
The PC3365 Series rackmount power distribution unit (PDU) is available in North American and European configurations. The North American version input power is 3-phase 120V/208V, 30A via a NEMA L21-30P plug. Power output is 120V and distributed through 24 IEC C13 computer-style receptacles, providing 8,640VA of power. The European version input power is 3-phase 230V/400V, 20A via an IEC 60309 plug. Power output is 230V and distributed through 24 IEC C13 computer-style receptacles, providing 11,040VA of power.
Pulizzi Engineering
Circle 207
Lighting controls
Miro wireless RF lighting control products offer fingertip control functionality. Powered by 900-MHz wireless communication technology, they allow extensive control capabilities without control wiring or a central processor. In addition to one-touch whole-house ON/OFF control, Miro features whole-house and room scene control, a panic function, vacation mode, and control of lamps/small appliances.
Watt Stopper/Legrand
Circle 208
