Handheld digital multimeter
The U1240A Series of handheld digital multimeters (DMMs) features dual and differential temperature capabilities as well as a microamp measurement function. Additional measurement functions include voltage, capacitance, and temperature. In addition, the device offers 10,000-count resolution, dual display, a dual-intensity backlight, harmonic ratio, a switch counter, and data logging.
Agilent Technologies
Circle 200
Speed drives
The V*S Drive line includes the VS1SP and VS1GV adjustable-speed AC drives, offered in a 115VAC version available up to 3 hp, a 230VAC version up to 60 hp, and 460V and 575V versions available up to 125 hp. V*S1 microdrives feature three models: the VS1MD microdrive/inverter, the VS1MX, and the VS1SM single-phase driver. Available from 5 hp to 700 hp, the VS1PF pump/fan drive uses a traditional inverter V/Hz control method.
Baldor Electric
Circle 202
Fluorescent luminaires
Profilo T5/T5HO fluorescent luminaires are constructed with a one-piece extruded aluminum housing. The fixture also features a drawer latching system that provides clean joints in continuous row-mounting applications. Aircraft cable suspension in 4-ft or 8-ft lengths is standard, and an optional dimming ballast is available. Optics include one- or two-lamp configurations with compact T5 or T5 high-output fluorescent lamps and a formed snap-in semi-spectactular parabolic louver with 45° angle cutoff to minimize glare. In addition, the luminaires are available as track-mounted units in two versions: one with dual-adapter mounting and one with a single-point mount.
Amerlux
Circle 204
Receptacles
The U-Line family of explosionproof receptacles has been expanded to include the K Series. Compatible with existing backboxes used to mount Killark Acceptor and Crouse-Hinds Ark•Guard 2 receptacles, K Series receptacles let MRO electricians swap out these products with the company's U-Line technology without installing a new backbox or requiring special adapter plates. Rated for Class I, Div. 1 and 2, Groups C, D when installed on Killark or Crouse-Hind backboxes, the product features a copper-free aluminum cover, epoxy powder coat, gasketed flip-lid cover, and a fiberglass-reinforced polyester insulating block.
Appleton/EGS
Circle 201
freeproductinfo.net/ecm
Fluorescent work light
This 84W portable tripod fluorescent work light with 360° illumination measures 33 in. long when folded. In operation, the light stands 5 ft 4 in. tall and can light workspaces up to 17 ft × 24 ft by producing 300W of incandescent light in all directions with no heat buildup. In addition, the light draws less than 1A of power. Other product features include two 42W CFLs set in a protected telescoping module that automatically powers on when the module is raised and powers off when lowered. The product also includes a tripod base, a shoulder strap for transportation, and a 12-ft, 18 gauge, 3-wire outdoor-rated power cord with its own storage compartment in the unit's base.
Husky
Circle 203
Lighting fixtures
The Brighton Series of wall- and ceiling-mount lighting fixtures is available in either corrosion-resistant cast aluminum with a heat-treated glass diffuser or injection-molded polycarbonate with a polycarbonate diffuser. According to the company, the diffusers are satin-etched for even dispersion of light. Suitable for wet locations, the product series includes incandescent, compact fluorescent, and HID.
Luraline/Brighton
Circle 205
Ground bars
These ground bars now include low-profile tamper-resistant stainless steel hardware to reduce incidents of theft. UL-listed, the ground bars are manufactured from electrolytic tough pitch 110 alloy copper.
Harger Lightning & Grounding
Circle 206
UPS software
SoftScale offers a software-based approach to UPS scalability. The product allows users to purchase the UPS capacity they need today while providing the ability to unlock additional capacity in the future through a software download. Systems will scale from 40kVA to 80kVA or from 80kVA to 120kVA, in 20kVA increments. SoftScale is enabled by advances in UPS design, which optimize the UPS efficiency curve. This allows the UPS to operate with the same high efficiency at 50% as it does at 100%, eliminating penalties of operating a UPS at a reduced load.
Emerson Network Power
Circle 207
Wire tap/splice
This insulation displacement contact (IDC) poke-in wire tape/splice allows for quick termination to the “run” connection. The product is available in two sizes. Once size accepts 12 AWG solid or stranded wire, and the second size accepts 18 AWG solid or stranded wire. In addition, the power tap for each size accepts 18 AWG pre-stripped solid wire. Contact current rating is 7A with an operating voltage of 600V maximum, the housing is UL 94V-0 thermoplastic, and the contact material is copper alloy.
Tyco Electronics
Circle 208
Hazardous location LED
The Model 27XL explosionproof LED light with XLT produces 60 high-intensity flashes per minute, according to the company. The light operates on 24VDC, 120VAC, and 240VAC 50/60Hz. UL-listed, the product is marine and type 4X rated and constructed to IP66. Offering an effective candlepower (ECP) of up to 134, it also features a standard low-inrush circuit design for greater compatibility with factory automation control systems.
Federal Signal
Circle 209
Audio/video connectors
This expanded audio/video product line now includes connectors for a variety of high-performance and high-definition applications. The connector line includes 3.5-mm stereo, HD-15 (screw terminal), HDMI, and DVI, with additional RCA QuickPort connectors in new colors for composite and component video.
Leviton
Circle 210
Industrial AC motor
The X$D extra severe duty Ultra motor features NEMA premium efficiency rating. Available from 1 hp to 300 hp, the totally enclosed fan-cooled (TEFC) motor offers low temperature rise and low vibration. In addition, the product's Six Star Bearing System protects and lubricates the bearing. Other product features include cast-iron construction and Class H insulation.
GE Consumer & Industrial
Circle 211
Enclosed drive controller
The Square D S-Flex is an enclosed drive controller for commercial pump and fan applications. According to the company, the controller features simple start-up, including preprogrammed parameters and quick installation with EZ-M mounting. The product also has easy wiring conduit knockouts on the enclosure as well as a dedicated terminal block. Microsoft Windows-based PCSoft software allows users to adjust parameters; store and transfer drive configuration files; monitor driver performance, including historical data; and configure, adjust, and control remotely.
Schneider Electric
Circle 212
Gen-sets
This new series of 100kW, 125kW, and 150kW Tier 3 gen-sets features advanced sound-attenuated enclosure systems. With a sound level of 67.5 dBA, the company says the 100kW unit is one of the quietest generator sets on the market. Available in steel or aluminum with two levels of sound attenuation, the gen-set and enclosure packages are suitable for all-weather outdoor use where local ordinances or circumstances require sound abatement.
Cummins Power Generation
Circle 213
Generator protector
The enhanced G60 generator protection system now supports Synchrophasor monitoring, allowing users to monitor how instabilities in their power system are affecting their points of generation. The device also offers new protection and control functions, including accumulated over-/under-frequency and enhanced RTD monitoring with separate temperature settings for alarming and tripping the generator.
GE Multilin
Circle 214
Phase detector
The 3129-10 phase detector complies with Cat. IV 600V and Cat. III 1,000V safety requirements. In addition, the device's extra-large clips allow users to measure wires up to 40 mm in diameter. Other product features include non-metallic clamps, bright red LEDs, audible recognition of phase detection, a line wire check function for detection of hot wires, and an auto power-off function.
Hioki
Circle 215
String lights
E-Lite 600V STW commercial-grade string lights feature a molded plug and connectors. UL-listed to UL1088, the string lights include three plug and connector NEMA configuration options, 150W-rated sockets, full metal shell bulb sockets, and four guard options, including the company's 212 RainGard clear guard. In addition, the units come standard with an extra-hard-usage ST cord in 50-ft and 100-ft lengths.
Ericson
Circle 216
