Product News
Nov. 1, 2002
Plastic thickness gauges These nonconductive, non-sparking, and non-marring plastic gauge sets replace metal feeler gauges for electronic repairs or where finishes could be easily damaged. The precision gage sets are available in 5-in. and 12-in. lengths with blade thicknesses from .001 in. to .030 in. Each blade is a different color for quick identification. They are made of polyester or vinyl and
These nonconductive, non-sparking, and non-marring plastic gauge sets replace metal feeler gauges for electronic repairs or where finishes could be easily damaged. The precision gage sets are available in 5-in. and 12-in. lengths with blade thicknesses from .001 in. to .030 in. Each blade is a different color for quick identification. They are made of polyester or vinyl and are non-corrosive.
Precision Brand Products
Circle 201
Lay-in wireway
Type 3R lay-in wireway is designed to protect electrical wiring against rain, sleet, and snow in outdoor applications and dripping water in indoor applications. The system consists of open-sided sections and fittings for increased access along the entire wiring run. The straight sections are made of 16- or 14-gauge galvanized steel and fastened by 14-gauge fittings. They're available in 4-in.×4-in., 6-in.×6-in., and 8-in.×8-in. sections.
Hoffman
Circle 202
Power monitoring software
EnergyDirector is a reporting and analysis program for controlling energy usage and determining patterns. The Web-based software monitors and measures the real-time energy usage of electronic or metered service, including gas, electric, water, and steam. Users can generate reports and analyze current and historical data. It also provides aggregate load and demand profiles, power quality analysis, and event alarming by screen alert, page, or e-mail.
Eaton/Cutler-Hammer
Circle 203
freeproductinfo.net/ecm
Engineered switches
This line of engineered switches is designed to protect elevator circuits, building emergency systems, and data processing rooms, and features a 120VAC fusible shunt trip switch for remote disconnection in crucial applications. Rated 600VAC and ranging from 30A to 400A, the switches offer withstand ratings as high as 200kA. A 3-pole fused switch, Class J fuse block, and NEMA 1 industrial enclosure are included.
Ferraz Shawmut
Circle 204
AC drives
The ACS 800 DriveIT low-voltage AC drive is packaged in a new enclosure that reduces its footprint by 50% over equivalent predecessors. It's available in sizes ranging in width from 6.5 in. to 13.78 in. Designed with integral EMC filters and chokes and rated at supply voltages of 230V to 690V, the drive is backward compatible with this company's previous family of AC drives.
ABB
Circle 205
Lighting fixtures
These redesigned vaporproof lighting fixtures are UL Listed for use with 90°C supply wiring and are suitable for use in wet locations, indoors or out. The fixtures include thicker silicone rubber gaskets and aligning pins for easier assembly than earlier models. They're made of die cast aluminum and are available in a variety of mounting situations, including box, pendant, wall bracket, and ceiling mounting.
RAB
Circle 206
Power module
The Quad-Plex power module can mix and match with electrical components to customize work stations using existing cables and provide three or four circuits with one dedicated circuit. It offers as many as five supply configurations, ranging from three utility circuits and one isolated circuit to three isolated ground circuits and one convenience circuit.
ECA
Circle 207
Project management software
Electrical industry workers can use the Smart Tools Project Manager software package to plan and budget projects or estimate and schedule client work and proposals. Information is presented in a worksheet format and can be printed to a high-quality chart. The charts and reports are customizable.
Ballantine & Co.
Circle 208
Generator set
The Ecostar is the first hydrogen-fueled internal combustion engine-driven genset. Because the unit operates on pure hydrogen, the only carbon-based emissions are from a small amount of burned and unburned oil present in the combustion chamber. The engine is coupled to a Class H, 2-pole, brushless, self-regulating alternator with a winding pitch designed to reduce the harmonic content of the output waveform. It's capable of producing 91.2kW and 114kVA at 480V in 3-phase power and 75kW and 75kVA at 277V in single-phase power.
Ballard Power SystemsCircle 209
Liquidtight fittings
ETP liquidtight fittings are designed for use in machine tool building, motor and transformer terminations, and robotics assembly, and offer a slim profile that eases installation in tight spaces. They also have a captive gland nut sealing ring, a reusable ferrule, and extra-long male threads that enable the use of a bushing to protect the conductors. They're available in .375-in. to 2-in. sizes and straight, 45°, and 90° molds.
O-Z/Gedney
Circle 210
Cable radius management unit
This half-circular-shaped, dual-channel unit is designed for multiple applications for maintaining the minimum bend radius of both copper and fiber optic cables. The unit is designed with a slot mount, which allows it to be seated on the sides of the cable management and wall mount racks. It can also be mounted directly to a wall.
ICC
Circle 211
Distribution centers
This standard line of AC and DC power distribution centers is designed to fit into industry standard 19-in. and 23-in. telecom racks. The DC models (LDM1, LDC1, and LDC2) are listed to UL 1801 and designed to EN60950 and offer circuit breakers that are rated as high as 10A per pole with a standard 10,000A interrupting capacity. The LAC1 series of AC distribution centers is available from 120VAC to 240VAC.
Carling Technologies
Circle 212
Hand towels
Kleaners are pre-moistened 9-in. × 11-in. towels packaged in resealable foil packets. They combine a synthetic towel with a liquid cleaner in a sink-free hand cleaning system. The cleaning ingredient is a natural citrus solvent, d-Limonene, which cuts oils, tar, adhesives, asphalt, wax, graphite, and other on-the-job soils. It's gentler to the skin than petroleum-based hand cleaners.
Klein Tools
Circle 213
PLC interface software
The PLC Pilot software package allows users to monitor and control programmable logic controllers from Palm OS mobile devices. The software supports the DirectNet protocol and interfaces with the Koyo DL05, DL105, DL205, DL305, and DL405 families. It eliminates the requirement for a personal computer when interfacing to these devices in the field and provides a general-purpose touch pad for writing to the PLC.
Pacific Microinstruments
Circle 214
Inverters
The Micromaster 4 series of universal drives for AC motors range in power from 1/6 hp to 300 hp. The series includes micro inverter, basic, variable-torque rated, and vector-controlled performance models that meet voltage ranges of 200/240V, 380/480V, and 500/600V. They feature digital microprocessors and IGBTs.
Siemens
Circle 215
Direct-burial cables
This line of direct-burial cables resists degrading after prolonged exposure to water or moisture. The cables feature a jacket made of an exclusive UV and weather-resistant material that will withstand years of burial without cracking or decaying. They are offered in 500-ft spools in 16/2, 16/4, 14/2, and 14/4 sizes.
Genesis Cable
Circle 216
Pad-mounted switchgear
The Kyle vacuum fault interrupter pad-mounted switchgear with visible break provides visual verification of contact status when distribution-switching procedures require indication of an open circuit prior to testing and verification. The visible break feature is available in two-position (open/closed) and three-position (open/closed/ground) configurations with ground switch capabilities.
Cooper Power Systems
Circle 217
PQ relay
The PQ1 power quality relay announces when disturbances on the power line are damaging or disrupting HVAC controls, telecommunications equipment, or other sensitive equipment. The relay has a response time of 500 nanoseconds for impulses and has built-in standard depth-duration curves for responding to voltage sags and swells. It can adjust to 50 Hz, 60 Hz, and 400 Hz power.
Power Standards Laboratory
Circle 218
Liquidtight connectors
These liquidtight metallic connectors are designed to connect flexible metal conduit while sealing out oil, water, dirt, dust, and fumes. The connectors employ this company's patented ferrule that offers pull-out protection four times greater than UL requirements. They're available in straight, 45°, and 90° designs.
Appleton
Circle 219
Plant maintenance software
The RSNetWorx v4.01 program for ControlNet provides advanced maintenance and diagnostic features for plant networks. In addition, the program's network configuration and management package supports Windows 2000 Terminal Server and offers a new online assistance center.
Rockwell Automation
Circle 220
Circuit monitor
After collecting and logging energy usage, the CM3000 circuit monitor analyzes data to forecast trend plots, averages, and demand metering in real-time. The information is served to the host circuit monitor and transparently to other devices connected downstream. It has 600VAC direct-connect metering inputs and doesn't require PTs, easing installation. The device also has built-in rail clips for DIN rail mounting.
Schneider Electric/Square D
Circle 221
Digital controllers
The SR80 series of digital controllers offers user-selectable inputs and ranges for thermocouples and RTDs, and user-programmable scaling for voltage, DC current, and mV inputs. The controllers are available in 72 mm, .25 DIN, and .125 DIN sizes. The .25 DIN SR83 and .125 DIN SR84 are available with dual outputs for heat/cool control.
Vespo
Circle 222
Load switching system
Using this company's CycloControl power frequency carrier transmission technology, the Z-Lynk is designed for load switching in large industrial facilities and campuses where wiring or wireless connections aren't reliable or cost-effective. The system's transmitters are connected at various voltage levels from low voltage (408V) to 33kV. Because the signal operates at the power supply frequency, coverage is 100%.
Cyclo Systems
Circle 223
EC&M Staff
